Drives: Stock, hotlava ,FRS 6mt
Oil cooler kit VS building my own kit
Hey guys! Don't get mad, I know this has been posted but my
Phone is wonky with this site so I can't search threads.. Anyway would it be more cost effective to piece together my own oil cooler kit or buy a premade kit? Would a universal kit work? Thanks ~~~kev |
| The Following User Says Thank You to 86dood For This Useful Post: | humfrz (06-30-2022) |
Rust bucket enthusiast
Do you have access to build custom AN lines and buy the correct fittings? And build your own mount? Those are really the biggest of the reasons to piece your own together, to customize those things.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#3 | |
![]() Second off, unless you're tracking your car, I don't reckon it needs an oil cooler. I'll summon ol @Ultramaroon for you - he has an oil cooler but doesn't track his car, nor does he live in a hot climate. (so, why did he install an oil cooler? - )
| The Following User Says Thank You to humfrz For This Useful Post: | Amputechture (07-19-2022) |
Drives: 2017 toyota 86
I am now 6 for 6 for building my own setups with zero issues. Pretty simple and easy really. Saves a decent amount of money too.
#5 | |
Drives: 24 GR Yaris, 23 GR86
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | MrSkubi (06-30-2022) |
Drives: 17 BRZ
I vote for R&D and tried and true but it's a little costly.
I went with peace of mind and use the HKS cooler. Works great! Highly recommend. Good luck with your project! |
#8 | |
But there is nothing special or propriety about it, or any kit. It’s basically just an oil cooler, some fittings, some hoses, a sandwich plate, and a method for mounting. Can purchase all that for about 1/3rd the price yourself. Coming up with a mounting solution is also incredibly simple. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Espi (06-30-2022) |
You can always piece together your own kit for less, but what is the value of your own time? Do you already own the necessary equipment to fabricate the parts?
Most folks will go with a pre-made kit that's tried and true, for just plug and play ease. Some folks like to make their own stuff, and will go that way. If you want a ready to go kit, CSG has many options in stock. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | DarkPira7e (06-30-2022) |
#10 |
For an oil cooler you can literally buy all the exact same components used, same setrab cooler mocal thermo plate or whatever brands of your liking. Can literally peice together a replica without the markup.
The only thing remotely “proprietary” is the mounting solution. With rivnuts, straight brackets, and L brackets you can easily mount the cooler in any fashion you like, almost exactly replicating any other kits or doing it a unique method/location of your liking. No frabrication, R&D etc… does not take much time at all either. If you have the ability to install an oil cooler you can make your own that’ll be just as effective. You can obviously start adding some complexity with a ducting solution if desired. How you bring air in / vent air out etc.. but most kits solution for this is either little to none, or incredibly easy to replicate. IE just dremel out fog light bezel and installing a vent/screen on fender liner. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | MrSkubi (07-01-2022) |
#11 |
I agree with everyone else here. If you have mechanical fabrication skills and tooling then yes you can put your own setup together with no issues. If not buy a pre made kit it will be less expensive in the long run.
#12 |
not playing cards
respect
#13 |
Hah that's it . I never did anything else than 2d vector graphics before but it's quite a friendly software once you start going. Not my preferred one (I did try a few else too) but for such an easy project it wasn't bad and too time consuming.
| The Following User Says Thank You to MrSkubi For This Useful Post: | Ultramaroon (07-01-2022) |
| Building a BRZ in 1/24 Scale | Tcoat | Off-Topic Lounge [WARNING: NO POLITICS] | 63 | 06-29-2019 09:48 AM |
| SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge | tws98 | Engine, Exhaust, Bolt-Ons | 0 | 05-28-2019 10:50 PM |
| Building my own oil cooler | Basket Case | Engine, Exhaust, Transmission | 13 | 01-06-2015 09:40 PM |
| Building my FR-S | Gillams | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 09-06-2013 12:37 PM |
