Old 01-03-2015, 08:36 AM   #1
Basket Case
Drives: 2013 Raven fr-s
Building my own oil cooler
Does anyone know where I can get jus the sandwich plate for the oil filter location? I know where I can get the actual radiator, and I can either make the lines or have the lines made for me locally.
This should be significantly cheaper then paying $500+ which I find insane...
Basket Case is offline   Reply With Quote
Old 01-03-2015, 08:39 AM   #2
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'm assuming you want a thermostatic plate?
http://www.racerpartswholesale.com/p...Sandwich_Plate
http://www.rallysportdirect.com/Mish...e-Thermostatic
You'll need spacers if you get the mishimoto one though.
Old 01-03-2015, 08:44 AM   #3
Basket Case
Yes indeed. Thanks. I don't know why I couldn't find that.
Old 01-03-2015, 08:54 AM   #4
Andrew025
Andrew025's Avatar
How much cheaper are you looking at for your kit?
Most that I've seen come pretty close to the $500ish already built kits.
Old 01-03-2015, 08:59 AM   #5
Basket Case
yeah, $500 is a lot of money...Im thinking around $300 when done. AN fittings are expensive, but not that expensive and the cooler itself should be around $100-150. I can make my own brackets now problem.
Old 01-03-2015, 09:04 AM   #6
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
check out hayden themostatic sandwich plates, is the FRS/BRZ m20x1.5 thread? they definitely have one if so.
if you're really cheap, volvo 740 turbos are plentiful in junkyards and have a nice setrab core. otherwise, if you search "nascar cooler" on ebay you can find plenty of cheap setrab or mocal cores.
you might want to run an oil temp and maybe pressure gauge while you're at it, to give you some feedback on how well your cooler is working.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 01-03-2015, 09:19 AM   #7
Basket Case
Yeah, I am definitely cheap...lol. But I do plan on buying a decent new cooler. And running a pressure and temp gauge is definitely one of the things I will be doing. The more info the better.
Old 01-03-2015, 04:59 PM   #8
Turbowned
Turbowned's Avatar
If you have not yet bought an oil cooler core, I have a new Setrab unit very similar to the one Perrin use in their kits. I was going to piece together my own kit but got lazy and bought the Perrin one, lol. PM me if interested
Old 01-03-2015, 05:32 PM   #9
vroom4
Check out the maximal performance kit, we already did what you are trying to do and made simple and cost effective brackets to boot. They are even on sale right now if you look through @Maximal post you can find the coupon code. (I'm on my phone or id give it to you)
vroom4 is offline   Reply With Quote
Old 01-03-2015, 05:33 PM   #10
Koa
depending on your goals, there are multiple options that may save you even more money and headache.
One popular one is the Forester XT oil cooler retrofit. Around $200 for OEM parts. Bolts right up, taps throttle body coolant, and has shown to keep temps down significantly and consistently, as well as the added bonus of warming the oil 2x as fast.
Old 01-03-2015, 06:04 PM   #11
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Ive got a mocal oil cooler im selling if you're interested in it for your diy.
Its from
http://www.maperformance.com/frs-oil...-ft86-ock.html
Im upgrading is the only reason.
$100 shipped if u want.
Derek
Sent from HTC M8 while in burnout mode
cruizin01 is offline   Reply With Quote
Old 01-03-2015, 08:31 PM   #12
Cartman
Cartman's Avatar
Drives: GT86
Maximal performance has an excellent oil cooler for $450
Turned out cheaper than me buying all the parts individually.
Cartman is offline   Reply With Quote
Old 01-06-2015, 08:28 PM   #13
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
i dont know about this brand's reputation, but i was looking at this sandwich plate + cooler combination before i decided to start the DIT based liquid oil cooler:
Sandwich plate
Heat Exchanger
plus hoses, fittings etc. for a total of $150 or so.
Only caveat is you can't use stock oil filters any more, so you have to use a Ford style oil filter.
I hope this helps.
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 01-06-2015, 09:40 PM   #14
sam69
Drives: GT 86
I bought this one off ebay and added a note that it was to fit a Toyota 86 and he sent me all the right bits for my car including the spacer sandwich plate........... http://www.ebay.com.au/itm/Thermosta...item3cdc773be6
Only issue was that the nipples that screw into the sandwich plate were JIS standard and the flare on the pipe end fittings was JIC standard but once this was sorted it has been a good setup.
I did clean up the ports in the sandwich plate for better oil flow but after comparing pics of some of the brand name cooler cores and this one I could not pick any difference so thought it was worth a go.
sam69 is offline   Reply With Quote
Building Sophie Justinyuen16 Member's Car Journals 27 08-19-2014 03:34 AM
building the fa20 ggiddix Scion FR-S / Toyota 86 GT86 General Forum 4 08-02-2014 12:04 PM
Building own website Atticus808 Off-Topic Lounge [WARNING: NO POLITICS] 19 04-08-2014 10:30 PM
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. mike the snake Engine, Exhaust, Bolt-Ons 1 01-31-2014 05:46 PM
Building my FR-S Gillams Scion FR-S / Toyota 86 GT86 General Forum 5 09-06-2013 12:37 PM
