Old 06-23-2022, 07:34 PM   #1
FrickingReallySlow
Drives: 2015 FR-S
Port Injector cleaning results
Used this shop in PNW in snohomish WA that just does injector cleaning and thought I'd share the test results. Only did my port injectors. Very happy with the service.
This shop also offer LIFT TIME cleaning for the same price ~90$! as long as its the same injectors and you've owned them. This guy also replaced all the seal/orings/filter which saved me $80 from Subaru etc. Had to give them a shout out. Also super quick turnaround (half a day in my case)
My injectors have ~50K miles so they weren't that bad.
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
bcj (06-24-2022)
Old 06-23-2022, 08:37 PM   #2
Decep
Drives: 2013 FR-S Series 10
Is it necessary at 50k? Dont think i've ever had to get injectors cleaned. My old mercedes turbo diesel probably could have used it at 200k but it still started up every time with barely a crank.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 06-23-2022, 10:41 PM   #3
It varies with use case, but on ethanol, you definitely want to get the injectors cleaned. Looks like OP's injector's were in pretty good shape.
DI injectors are more important to clean than PI, as the DI is what is used for fine fueling requirements.
Not all fuel injector cleaning services can do DI.
Decep (06-25-2022)
Searching For a replacement USB port for the factory port for aftermarket radio Kutanks Electronics | Audio | NAV | Infotainment 20 08-21-2021 09:12 PM
Port Injector Seal/O-Ring kimcheefists Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 01-24-2020 06:34 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Port injector scaling ztan Software Tuning 28 04-10-2016 04:45 AM
