Drives: toyota 86 MT 2.0
Engine parts to cover during engine wash. Missed the ECU.
Hi Guys,
Had an engine wash the other day in this local car wash and forgot to cover the ECU, well im not sure if it was the ECU of fuel injector module which is located near the fusebox, because I remember the ECU of the 86 is just under the dash passenger side ammi correct? does anyone have the same experience? Hopefully ECU was not damaged. So far my 86 is still running normal with no unusual sounds or abnormalities. I had it pressure washed. Hopefully everything is just fine especially the ECU. Had alternator and other electrical components covered, So what are the other parts that needs to be covered. Thanks a lot. |
Drives: 2020 GMC Canyon Denali Diesel
It'll be fine
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| The Following User Says Thank You to Opie For This Useful Post: | Ultramaroon (06-21-2022) |
#3 | |
Be Kind
Drives: 2020 86
If you had caused an issue, you'd already know about it. You would have known about it first start up after the wash.
| The Following User Says Thank You to Wally86 For This Useful Post: | Ultramaroon (06-21-2022) |
Thanks Guys! Yeah so far ao good i dont see, hear or feel any problems. Hopefully i wont have long term issues tho because of the engine wash I had. Thanks guys
| The Following User Says Thank You to captainsatch For This Useful Post: | Wally86 (06-22-2022) |
FIFY
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DarkPira7e (06-22-2022), Wally86 (06-22-2022) |
Be Kind
Drives: 2020 86
You should be ok. Everything in the engine compartment should be IP65 or greater. I personally do not cover anything when cleaning my engine but do not use a pressure washer.
Drives: 14 FRS Monogram, 05 Mazdasped Miata
I wouldn't use a pressure washer either. You can get everything you need off with a regular hose and brush.
| How to wash your engine bay area (DIY) | Packofcrows | DIY (Do-It-Yourself) Guides | 23 | 09-26-2020 11:39 AM |
| **SOLD**Blue engine Cover and Grimmspeed Pulley Cover | Husker BRZ | Engine, Exhaust, Bolt-Ons | 2 | 03-24-2016 01:05 PM |
| WTB: OEM Engine Cover | PhreshhWun | Canada Classifieds | 2 | 02-05-2015 03:35 PM |
| Engine Cover | Sailors14FR-S | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 04-29-2014 02:44 PM |
| WTB Engine cover! | Khazzy | Engine, Exhaust, Bolt-Ons | 10 | 08-23-2013 06:36 PM |
