Old 06-15-2022, 12:13 PM   #1
Yeel
Very aggressive engine braking all of a sudden
Yesterday, out of nowhere i noticed that my car has way more aggressive engine braking. Its very noticeable that as soon as you lift the throttle it slows down alot, before you could pretty much coast in gear with no gas and it would only decrease a tiny bit.
Even downhill, in gear with no gas it slows down unless the hill is very steep. Something feels wrong.
I thought first that the brakes might be dragging on? I drove the car for 2 hours on the highway, stopped and put my hand around the wheels and there were no heat at all from any corner, so i dont think the brakes are dragging. The other part i would think would be an issue is the tune? But that has been the same for over a year so i dont see how that could be the issue.
Next time im out i'll try and let it coast downhill not in gear, and i should be able to tell if its any brakes on. But i dont think this is the issue as mentioned above.
Yeel is offline   Reply With Quote
Old 06-15-2022, 12:16 PM   #2
Lantanafrs2
Drives: 2013 frs red
Auto I assume?
Old 06-15-2022, 12:23 PM   #3
blatantanomaly
Drives: 2016 BRZ Limited
The new engine braking behavior you're describing sounds more correct than the older description.
My total guess is that your throttle plate wasn't closing all the way before but now it is. My engine braking is strong enough that if I don't use it, I won't be able to slow down enough to make corners at the track even with upgraded pads. The only modification that might add power to my engine is a K&N filter.
Are you able to collect any data through an OBD-II dongle or something?
Addendum: Reading the reply above made me realize that I assumed your car is manual.
blatantanomaly is offline   Reply With Quote
Old 06-15-2022, 10:43 PM   #4
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Is the air filter old or possibly got water into it recently?
Has Iceland been popping off again :/
JD001 (06-21-2022)
Old 06-18-2022, 09:32 PM   #5
Lantanafrs2
Did you move the floor mat?
Old 06-20-2022, 03:06 PM   #6
humfrz
Old 06-21-2022, 02:36 AM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Guess he hasn't been back.
Old 06-21-2022, 03:12 AM   #8
JD001
JD001's Avatar
Drives: Subaru BRZ
Have you checked/changed your cars fluids?
Poor idle after engine braking, OFT demasrv Software Tuning 3 11-13-2020 10:54 PM
Sudden lean 17AFR, but then sudden rich 10AFR??? No codes D-VO Software Tuning 4 12-11-2019 12:17 AM
Engine Braking or lack thereof arren123 Issues | Warranty | Recalls / TSB 28 03-14-2018 06:46 PM
Engine Braking - Questions soulreapersteve Engine, Exhaust, Transmission 19 06-20-2015 03:08 AM
Engine Braking Wattage Scion FR-S / Toyota 86 GT86 General Forum 75 01-16-2013 02:51 PM
