Old 11-13-2020, 10:21 PM   #1
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
Poor idle after engine braking, OFT
I'm getting a really rough idle , sometimes to the point where my car is just dying while trying to idle. It's most prevalent if I'm getting off the interstate and engine brake on the off ramp.
I can try to get some logs here soon...but is anyone having something similar?
I'm running:
2013 BRZ
OFT Stage 2+ (whatever the latest as of 12/2019 was)
Invidia catless front pipe + Q300
OpenFlash headers
~70k miles
demasrv is offline   Reply With Quote
Old 11-13-2020, 10:27 PM   #2
alphasaur
friendly
Drives: 17' 86
What are fuel trims like? Sounds like vacuum leak
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 11-13-2020, 10:31 PM   #3
demasrv
demasrv's Avatar
Last I checked +/- ~5%? I'll grab a log tomorrow.
How could I check for vacuum leaks on this guy? I'm used to working on older cars. This thing spun a rod bearing at ~57k and I got a new short block. Then had the valve spring recall done. I don't remember this being an issue before the recall so it's entirely possible something just isn't sealed up.
Old 11-13-2020, 10:54 PM   #4
steve99
Log Boost with oft its manifold pressure reliative to atmospheric
at idle should be about -10 psi
check fuel trims at idle are less than 10%
check DI computer has all three mount bolts in and tight
if ok bump idle 50 or 100 rpm
adjist overun fuel resume to cut in 100 or 150 rpm sooner
New engine with poor idle. need direction Rabrooks Engine, Exhaust, Transmission 7 04-21-2020 10:10 PM
Engine Braking or lack thereof arren123 Issues | Warranty | Recalls / TSB 28 03-14-2018 06:46 PM
Engine Braking - Questions soulreapersteve Engine, Exhaust, Transmission 19 06-20-2015 03:08 AM
Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon WTF Issues | Warranty | Recalls / TSB 12 06-14-2014 10:40 PM
Engine Braking Wattage Scion FR-S / Toyota 86 GT86 General Forum 75 01-16-2013 02:51 PM
