Old 06-14-2022, 01:24 PM   #1
FRS-I
FRS-I's Avatar
Drives: 2013 10-Series FRS
Correct Tire Sizing Help
I have 18x10.5 in the rear and 18x9.5 in front. I'm having the issues of ordering tires through my company but can find 275/35/18 for the front and 295/30/18 is the different aspect ration going to cause issues? I did a calculator but am not sure if the difference is reasonable or not. Or a better question might be what sizes will cause the least issues with this setup?
Taking time to destroy before I rebuild.
FRS-I is offline   Reply With Quote
Old 06-14-2022, 04:40 PM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
What offset are the wheels? What suspension setup?
275/35-18 are significantly taller than stock at 25.6" (stock = 24.7" diameter). 295/30-18 are only a bit taller than stock at 25.0" (but obviously a LOT wider).
Not gonna vouch for fitment, but you'd have an easier time with sizes like 245/35-18 front (24.8") and 265/35-18 (25.3") rear...
Old 06-15-2022, 10:33 PM   #3
bradsm87
Drives: It has 4 wheels
There is always a compromise around those sizes with only 1" difference between front and rear because you need 25mm wider tire to get the same sidewall bulge/stretch BUT you need 40mm difference to get the same tire outer diameter (eg. 255/35R18 and 295/30R18 are same diameter).
A good compromise is a 30mm split like:
255/35R18 F
285/30R18 R
or:
265/35R18 F
295/30R18 R
The 255/285 combo is closer to the correct diameter and a better fit for the rim widths. That's what I'd be running.
bradsm87 is offline   Reply With Quote
Tire sizing Nigruto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 05-20-2021 02:11 PM
plus 1 wheels, tire sizing question soundman98 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-21-2019 05:29 PM
Help in picking the correct wheel and tire ikarntspel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 06-07-2016 11:14 AM
RTR tire sizing SVThis Tracking / Autocross / HPDE / Drifting 10 02-19-2013 08:10 PM
Plus 0 tire sizing Brzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-30-2012 08:15 PM
