Old 06-07-2022, 04:22 AM   #1
Infinity3000
Drives: 86 GTS
Custom rear diffuser/cut bumper idea. Suits single/twin exit
Hi,
I completed this mod to my 86 recently and thought I'd share
I've used a modified "TRD v2 Style" rear lip, a metal mesh panel, and some rubber edging, and replaced the stock reverse/fog light with one designed for a Ford F-150.
First step was to use a Dremel to cut the rear bumper off, leaving space to mount the new reverse/fog light.
I then tidied up the edges with rubber edging. You could leave it like this if you want a more aggressive look.
Cutting the mesh to the right shape following the contours of the rear lip was the hardest part, but pretty happy with how it turned out. There are two metal brackets holding the rear lip on (mounted to the exposed ends of the heat shield bolts) as well as the two stock push clips at each end. The mesh is held in place with sikaflex.
You can cut the hole in the mesh wherever you want, so could suit a variety of exhausts. I have the MXP Comp RS catback.
Infinity3000 is offline   Reply With Quote
The Following 12 Users Say Thank You to Infinity3000 For This Useful Post:
brandonblt2 (06-28-2022), FrickingReallySlow (06-12-2022), Jdmjunkie (06-07-2022), Kittykate (06-14-2022), Mr_Eyo (06-14-2022), new2subaru (06-07-2022), NLSP (06-15-2022), NoHaveMSG (06-11-2022), sato (06-11-2022), soundman98 (06-07-2022), SuperTom (08-22-2025), Wally86 (06-07-2022)
Old 06-07-2022, 05:13 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm .. imho very good idea & well executed. And custom-cut mesh really can accommodate any type of exhaust, and to me seems that result will look better then stock bumper with exhaust hole cover on one side.
Old 06-07-2022, 06:28 AM   #3
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
Similar in some ways to the old Lotus Elise rear.
ACT86 is offline   Reply With Quote
Old 06-07-2022, 06:42 AM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by Infinity3000 View Post
Hi,
That looks SO good!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 06-07-2022, 07:34 AM   #5
Infinity3000
Drives: 86 GTS
Yes I was inspired by Lotus and other exotics where the mufflers are semi-exposed.
Would love an Elise one day....
Old 06-07-2022, 07:41 AM   #6
Infinity3000
Drives: 86 GTS
Originally Posted by Wally86 View Post
That looks SO good!
Thanks guys
The Following User Says Thank You to Infinity3000 For This Useful Post:
Old 06-11-2022, 02:50 PM   #7
gkubed
gkubed's Avatar
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
This actually looks really cool and I've never seen it done! A great idea and great execution. Well done.
Also, nice wheels. I wish I didn't destroy mine.
gkubed is offline   Reply With Quote
Old 06-11-2022, 02:54 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Very nice. I am looking to do something similar since I don’t care for the full cut bumper look.
Old 06-11-2022, 05:46 PM   #9
sato
sato's Avatar
Drives: Dodge Patitas
Very clean
Old 06-11-2022, 07:47 PM   #10
PulsarBeeerz
Drives: JRSC BRZ SOLD
Very well executed.
PulsarBeeerz is offline   Reply With Quote
Old 06-14-2022, 09:38 PM   #11
Kittykate
Drives: 2015 FR-S
Sweet! And it gets rid of the really weird V light I've never liked.
Kittykate is offline   Reply With Quote
Old 06-15-2022, 06:50 AM   #12
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
For the most part I like it. I just don't care for the cab light back there.
dragoontwo is offline   Reply With Quote
Old 06-23-2022, 11:48 PM   #13
Kittykate
Drives: 2015 FR-S
How'd you mod out the divot in the rear lip?
Old 06-28-2022, 03:32 AM   #14
Infinity3000
Drives: 86 GTS
I cut two triangles from some sheet metal to bridge across the divot, stuck them in place with some glass fibre body filler (Septone brand) and then went over it again with the filler. Then did lots of sanding to get it smooth and even.
Kittykate (08-22-2022)
Rear bumper for single exit? FR-Sky Cosmetic Modification (Interior/Exterior/Lighting) 3 06-02-2017 02:48 PM
Custom FRS Black rear bumper/diffuser adjusts Great Lakes 0 08-22-2016 07:16 PM
Rear diffuser for single exit exhaust Fresh31 Cosmetic Modification (Interior/Exterior/Lighting) 3 11-12-2015 11:11 AM
DIY: Single exit exhaust diffuser for less than $10 johan DIY (Do-It-Yourself) Guides 17 12-18-2014 06:33 PM
Single exit rear diffuser/valance? gabeg86 Cosmetic Modification (Interior/Exterior/Lighting) 9 02-20-2014 05:14 PM
