Drives: 14 frs; drift spec
slow crank, followed by clicks, no start
battery has already been replaced, i’m thinking it’s most likely something in the wiring harness or maybe bad spark plugs? not my car it’s a friend’s
https://streamable.com/pbjal2 |
Rust bucket enthusiast
Did you put a new battery in and try right away? Old "new" batteries sometimes still need to be charged. Slow crank to clicking is indicative of not enough power. Get a battery pack on it or let it charge on jumper cables for a while
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
Drives: BLue 2013 frs
Sounds like battery is dead.
Battery/Battery connections. Clean everything up.
I think we need a sticky of how to use a volt meter! |
In addition, I suggest the battery be put on a charger fer ah few hours.
ProCrastinationConsultant
Don't know why, but got called an a hole last time I brought up that unless everyone was bitten by a special radioactive spider, none of us can see electricity...
welcome to the club?
we meet on tuesdays.
#9 | |
#10 |
Drives: 2023 Toyota GR 86 Cup
Car driven through water recently? Hydrolocked engines sound like that...
2023 GR Cup Car
#11 |
That's actually a good thought..
#12 |
#13 |
Those cable ends look like crap!
#14 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Spark plug don't make an engine crank slowly, they fail to ignite, the cylinders get flooded and washed with gasoline, compression drops, cranking goes faster. Get voltmeter, place positive lead on the starter B+ terminal, put negative lead on starter body, get your friend to crank it, note voltage. Do the same with the positive and negative leads directly on the battery posts. A good battery should still crank in the high 11V range, it's not, it's dead. the voltage while cranking at the starter shouldn't be more than half a volt below what you measured at the battery posts. If it's significantly lower you've got a voltage drop. Figure out if it's on the positive or ground side. Positive lead on batter post, negative lead on starter B+ terminal, crank, note voltage, should be a small fraction of a volt. Positive lead on the starter body, negative lead on the battery negative post, crank, note voltage, should be a small fraction of a volt. |
| Changed battery - slow start? | lumbeardjack | Issues | Warranty | Recalls / TSB | 3 | 09-19-2020 10:45 AM |
| Car clicks but won't crank. Battery or Starter? | JERM^ | Issues | Warranty | Recalls / TSB | 93 | 09-14-2019 10:11 AM |
| Car slow to start? | ericmpena | Issues | Warranty | Recalls / TSB | 10 | 08-28-2013 02:29 PM |
| Sales start to slow down? | motofan | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 04-03-2013 07:39 PM |
| slow start | GREATNEESSS | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 12-30-2012 08:49 PM |
