Northwest AK, ID, OR, WA
Old 05-31-2022, 01:23 PM   #1
Ducati.Femme
Drives: 2017 BRZ Limited - Pearl White
Wheel Spacers on stock PP rims 2017+
Hey All,
I tried doing a search, but my lord it's a lot of info, and a lot that didn't help.
Is there a spacer that can be used on the stock PP rims on a non-lowered car that just bump out the wheels to be a bit more 'flush' with the fender?
Thanks in advance!
Ducati.Femme is offline   Reply With Quote
Old 05-31-2022, 05:52 PM   #2
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I use both 15mm and 20mm spacers that have a hubcentric lip for the oem wheels. You will need to install 3” studs like ARPs to accommodate them but thats pretty easy.
The 15mm were easy to find on amazon but the 20mm were not because most in that size are the bolt on type which I don’t prefer for my use case (racing).
You could probably do 5mm and maybe 10mm without changing studs. You can also get the bolt on type too since they're seemingly plentiful.
PRO86 | WTCC | STL
The Following User Says Thank You to rice_classic For This Useful Post:
Ducati.Femme (05-31-2022)
Old 05-31-2022, 06:15 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I gave my friend a 15mm bolt on spacer for the front, and 25mm bolt on for the back, was pretty good. Buy the bolt on spacers, well worth the expense if you're not buying new wheels any time soon.
Edit: if it wasn't obvious, his car is the series.yellow 2017 pp. It also has KWV3 coilovers, but the stock pp wheels and tires with the spacers, it is still fairly flush when it was stock height
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following User Says Thank You to DarkPira7e For This Useful Post:
Old 05-31-2022, 06:44 PM   #4
Ducati.Femme
Brilliant, thanks guys!
Old 06-03-2022, 05:57 PM   #5
Four_wheel_drifts
Drives: Whiteout track car; lava donor
I NEVER get to correct Rice_Classic, so I'm taking the opportunity right now to do so! 5mm spacers are a YES with OE studs. 10mm are a definite NO with OE studs. The OE studs are barely long enough for enough thread engagement with 5mm.
Four_wheel_drifts is offline   Reply With Quote
The Following User Says Thank You to Four_wheel_drifts For This Useful Post:
rice_classic (06-04-2022)
Old 06-03-2022, 11:13 PM   #6
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I had 20mm/30mm spacers with my non-PP wheels. I believe the offset on the PP wheels is +5 over non-PP wheels so the equivalent of 15mm/25mm spacers. With coilovers/RLCAs and camber around -2.5 the front wheels were a bit too tucked and the rears were a bit too flush for my taste. If I were to do it again, I would get 25mm spacers front and back. That would be equivalent to 20mm spacers square on PP wheels.
If you don't have coilovers and can't get as much camber, your fitment will be different obviously.
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Ducati.Femme (06-06-2022)
Wheel Spacers on stock wheels?? Husker BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 140 08-01-2020 01:05 PM
spacers question stock frs rims nammie81 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-05-2016 08:19 AM
help with spacers to clear ap sprint kit with stock rims didinyc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 11-23-2014 01:27 PM
Stock rims +coilovers +spacers +LCAs ang31ito Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 04-03-2014 04:22 PM
Spacers with RCE Yellows on Stock Rims/Tires? husker741 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-04-2013 04:21 AM
