Old 05-26-2022, 05:42 PM   #1
Mr_Brian
Code P0133
My car started throwing code P0133 the car has a JDL UEL uncatted header and I think a stage 2+ OFT tune. After doing some research it seems like this is related to the front o2 sensor and could be related to having a o2 sensor spacer. My question is does this o2 sensor have a spacer or is this normal? The thing circled in blue is what I'm not sure about is that a spacer?
Mr_Brian is offline   Reply With Quote
Old 05-26-2022, 06:59 PM   #2
waifu_zn6
waifu_zn6's Avatar
Drives: 2015
did that spacer come with the header?
waifu_zn6 is offline   Reply With Quote
Old 05-26-2022, 07:21 PM   #3
Mr_Brian
Is it a spacer? I bought the car like this and I'm not sure what it's supposed to look like on a aftermarket header.
Old 05-26-2022, 08:43 PM   #4
waifu_zn6
waifu_zn6's Avatar
Drives: 2015
ive done a uel header mod once and ive never seen an o2 sensor like that. it should look like the pic, that flat part should be close to the header piping. that "extension" might be throwing off your cars readings.
The Following User Says Thank You to waifu_zn6 For This Useful Post:
Mr_Brian (05-26-2022)
Old 05-27-2022, 12:07 PM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
The upstream 02 sensor screws directly into the manifold. Often a spacer is used on downstream 02 sensor to avoid throwing a P0420 (Cat insufficiency code) with hi flow or catless manifolds.
The Following User Says Thank You to blsfrs For This Useful Post:
Mr_Brian (05-27-2022)
Old 05-27-2022, 05:43 PM   #6
Mr_Brian
I finally got the o2 sensor off and that was a spacer I removed it cleared the codes and drove about 20 miles so far so good.
The Following User Says Thank You to Mr_Brian For This Useful Post:
blsfrs (05-29-2022)
Throwing CEL (P0133) after OFT Tune with new headers Mttogo Software Tuning 4 01-21-2020 01:40 AM
DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 Trap63 DIY (Do-It-Yourself) Guides 0 06-14-2018 05:52 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 09:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 11:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 02:27 AM
