Old 05-26-2022, 02:42 PM   #1
yEEt42069
Drives: 2018 Subaru BRZ
Loud noise when taking hard left turns
I'm hearing a loud noise coming from the front when I take hard left turns. The sound correlates to the engine rpms, the higher the rpms, the louder the sound. I already checked my fender liners and suspension parts, nothing seems to be rubbing.
I believe the culprit is the JDL 4-2-1 EL header I have. I think it's rubbing against the skid plate because when I removed the skid plate, I saw some marks on the header itself (it has cerakote coating.) I already tried hammering out the skid plate but that didn't seem to do anything. I'm not sure if I need to hammer it out more or what. Anyone have any ideas?
yEEt42069 is offline   Reply With Quote
Old 05-26-2022, 02:44 PM   #2
RedReplicant
Drives: None
Hammer more or get stiffer motor mounts
RedReplicant is offline   Reply With Quote
Old 05-26-2022, 03:44 PM   #3
yEEt42069
The car is still a daily so stiffer motor mounts would get annoying. I think I’ll try to run an event without a skid plate and see if that does anything
Old 05-31-2022, 04:57 PM   #4
Matt93SE
Drives: 2013 FR-S, 2017 BRZ
Just a note.. that skidplate also works to direct air through the engine bay. take it off and you'll reduce airflow through the radiator and possibly cause a cooling issue. YMMV.
They only take a couple minutes to remove so you could pull it off for a single session and see if it goes away.
another option is to space the whole thing down with some longer bolts and washers between the plate and the chassis. it'll be fiddly to get them all in there, but it's an option to consider.
Matt93SE is offline   Reply With Quote
Old 05-31-2022, 06:10 PM   #5
yEEt42069
Thanks that’s good to know. I didn’t think to try spacing out the skid plate, I’ll give it a try once I figure out what size bolts I need.
Old 06-01-2022, 09:07 AM   #6
Matt93SE
Bunch of M8 and some M6. start around 25mm long.
the other thing would be to just keep clearancing the plate. pull it off and put it on some soft ground (dirt or grass) or over a sandbag and then start banging away at the spot where it's rubbing. you'll pound some clearance into the plate without deforming everything everywhere.
the other thing that comes to mind is the overpipe-- I've heard of it rubbing on the subframe in some cases. you might be able to loosen the bolts and rotate it a little to give it more clearance to the chassis. don't recall if that was mentioned in this thread already, but it's something to look at.
Engine mounts-- I have some Megan racing mounts in my car and it's really not annoying at all-- I don't notice any nasty engine vibes or cabin noise from the engine. I also don't have any exhaust rub issues or anything. Then again, mine's a stripped race car and every joint is solid; I drive with earplugs and expect vibrations in the cabin cause race car so what I may just consider race car noises may be a total no-go for a street car.
Popping/creaking noise in hard left turns TheLaughingMan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 09-20-2019 05:01 PM
Loud Sudden Rattling/Scraping Noise from Left Front Wheel revaholic Issues | Warranty | Recalls / TSB 2 05-21-2018 07:33 AM
Humming noise on left turns. kphan Issues | Warranty | Recalls / TSB 10 10-27-2016 11:49 AM
Vibration on hard right turns ravisraval Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 10-22-2015 09:33 AM
Switching the Turns and the DRLs, possible, or just too dang hard? VesperLynn BRZ First-Gen (2012+) — General Topics 3 08-18-2013 09:38 AM
