Drives: 2025 Toyota GR86 Premium PP
Thinking of picking up a brand new BRZ or GR86 mainly as a fun car for autocross. Any thoughts as to which trim level is best to start with for autocross?
It seems like it really comes down to the 17" wheels and their tires versus the 18" wheels and the "better" tires along with the base model weighing 66 pounds less. Seems like I'm debating a few scenarios: 1. Get the base model and immediately switch out the tires on the OEM wheels. 2. Get the base model and immediately get lighter weight wheels with better tires (if the OEM wheels aren't good for autocross). 3. Get the premium/limited model and run the included tires for awhile in order to get used to the car, then swap out to better tires later. Any thoughts as to what is best if you're starting from scratch? If the premium/limited model's wheels and tires aren't really that good then it seems like I might be better off putting the $2500 price difference into better wheels and tires for the base model since I don't really care about the other stuff you get with the higher trim levels. |
At the track
Drives: '14 FRS - Former e92 M3
If you don't care for the interior differences just get the base.
You're going to end up buying a set of wheels/tires for either car eventually anyway and you can put your savings on purchase price towards that.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
| The Following User Says Thank You to Kelse92 For This Useful Post: | soundman98 (05-25-2022) |
#3 | |
Drives: 2018 BRZ
If you are looking to be competitive than you'd need to choose which class to aim at and work within the limits of that class with regards to wheel and tire specs. I'd say that it would make more sense to get the base as the 18" Pilot Sport 4 tires won't be competitive and you'd need to swap tires at the very least. |
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | timurrrr (05-26-2022) |
Drives: Subaru BRZ
The sidewalls of PS4's are made of noodles, I went with the base trim, snagged OEM 18" wheels, and put better tires on them.
Drives: Subaru BRZ
#7 | |
Drives: 2017 BRZ PP, 2004 WRX
It's competitive in DS for the most part, even in regions that are highly competitive themselves. STR is where the gen 2's are classed, but remember the people running there now are just setup with suspension, wheels/tires, and exhaust really - no tuning is available yet. And there, you're still up against ND2's that are modded and quick.
IMO, if you're going for competitiveness, you're probably getting the lowest offset wheels the rules allow, which aren't OEM. 245's are what people are fitting and are swapping out the front lug studs to do it. No idea what the trick is or why you need this - probably has more to do with not being able to fit the same set of wheels in the rear (because of the new plastic bit) you need for clearance for the front (reason for the spacer and extended studs). If it's me, look, get the car, any trim, any stock wheel, get 225 200TW tires and go have fun and learn the car. If you need to move to 245's and lighter wheels later, you can do so.
| The Following 2 Users Say Thank You to cmiovino For This Useful Post: | FastLap (05-25-2022), strat61caster (05-25-2022) |
D-Street
OEM size wheels, 200tw tires, oem crash bolts, alignment, maybe a front bar and some koni yellows, done. If you want to blow an extra $2k go for MCS dampers. Btw, a competitive STR/STX build is in the $5k-$10k range if you buy reasonably priced parts, you can get 95% of the performance for under $4k if you find the right used parts. You can spend $20k but it won’t be worth it. |
| The Following User Says Thank You to strat61caster For This Useful Post: | mike2100 (05-26-2022) |
#10 | |
Last time I did autocross it was in S2000s where I could be fairly competitive with just some RE01R tires and a thick front sway bar so I'm looking for something similar where I don't have to modify the car too heavily. |
#11 |
Drives: 2022 BRZ; 2014 BRZ
DS is your answer. The car is quite competitive currently. You'll want 200tw tires (Falken RT600 or Yokohama A052) in probably 235 width +/- depending on availability, regardless of which trim you go with. I believe in getting an extra set of wheels as well, but they are street tires, more or less, if you want to save some money in the short term. Put the front crash bolts in, they're $10, and go have fun. This is the recipe I've gone with and it's certainly good enough to trophy at national events.
Everyone that I've talked to with a front bar and no other suspension mods, has complained about understeer, so I would skip that until you're prepared to drop another $1-2k in shocks that aren't even out yet, or $4k in the ones that are.
| The Following User Says Thank You to foshjowler For This Useful Post: | mike2100 (05-26-2022) |
#12 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
| FS/FT: OEM 2022 BRZ Premium/Base 17" wheels | patsimca | Canada Classifieds | 3 | 04-13-2022 09:34 PM |
| Swap TRD (Limited) LED dash gauge cluster into base 2017? | Scremin@ATS | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 03-26-2019 10:07 AM |
| 2017 Subaru WRX STI, STI Limited, WRX, WRX Limited, WRX Premium | mark0006 | Other Vehicles & General Automotive Discussions | 0 | 10-27-2016 06:22 PM |
| WTB: BRZ PREMIUM OR LIMITED | FA20_BRZ | Cars for Sale/Trade | 1 | 06-16-2014 11:41 AM |
| Premium vs. Limited? | gt8613 | BRZ First-Gen (2012+) — General Topics | 62 | 11-20-2013 02:49 PM |
