Drives: 2017 86, 94 Supra TT, 93 MR2T,90GT4
Swap TRD (Limited) LED dash gauge cluster into base 2017?
I’ve found limited info on this, only one thread talks about swapping it into a 2015.
I have a 2017 base model. Does the Limited /Trs Gauge cluster plug right in? If so, has anybody done it? We’re you able to set the mileage using tech stream or any other way? The 2015 thread indicated it could be programmed. Any help is appreciated, I really wanted the TRD model but don’t want black paint, wish they would have opened up the options! Last edited by Scremin@ATS; 03-24-2019 at 07:47 PM. |
Panda Trueno
Drives: No twin now.
There are multiple threads on this forum. Iwould suggest you start reading here. http://www.ft86club.com/forums/showt...=114910&page=2
| The Following User Says Thank You to Summerwolf For This Useful Post: | Tokay444 (03-25-2019) |
By the time you went through the cost and hassle of changing it you may as well have just traded it in for one with the display.
| The Following User Says Thank You to Tcoat For This Useful Post: | Tokay444 (03-25-2019) |
#4 | |
Panda Trueno
ehhh, seems like a pretty easy swap from what people are saying. Only thing that's kind of dippy is the control panel being made that goes in the center console's blank space. Doesn't look very factory. |
#5 | |
If you change the cluster for a used one you need to deal with the security coding between the cluster, immobilizer and ECU. It is not a simple swap and go.
#6 | |
Panda Trueno
http://www.ft86club.com/forums/showthread.php?t=129867 |
#7 | |
Pavement Grey
Just as simple as Toyota could have given the 86 more power! Just that simple! Nothing is ever that simple...... |
| The Following User Says Thank You to Sasquachulator For This Useful Post: | Jordanwolf (03-26-2019) |
#8 | |
Panda Trueno
Why would a cluster swap with the same plug and a proven way to do it not be in the realm of cheap when the other option is trade the car in, lol. |
| DIY - Gauge Cluster LED swap | Blackrsx | DIY (Do-It-Yourself) Guides | 216 | 11-04-2021 10:40 AM |
| 2017 Limited Gauge Cluster | halleffect | Electronics | Audio | NAV | Infotainment | 26 | 10-22-2020 07:32 PM |
| Used gauge cluster swap | hachi roku [86] | Electronics | Audio | NAV | Infotainment | 0 | 09-23-2018 06:26 PM |
| BRZ cluster gauge swap? | InYOHface | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 03-25-2017 06:31 PM |
| 2017 Limited Gauge Cluster | halleffect | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-16-2017 03:55 AM |
