Old 05-25-2022, 01:42 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
FA24 clutch/flywheel
I've done a bit of digging, the OE Subaru part numbers are not interchangeable between FA20 and FA24.
I also have not seen any aftermarket compatibility yet. Is the FA24 clutch/flywheel setup unique to that engine?
Old 06-10-2022, 03:35 PM   #2
mav1178
mav1178's Avatar
I guess according to ORC their clutch kit for FA20 works for FA24.
http://www.ogura-racing.com/pdf/ORC_86-GR86-BRZ.pdf
I might need to find a test car for this in the near future, will post a relevant thread when the time is right.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
DarkPira7e (06-10-2022), Scargod (01-11-2025)
Old 01-11-2025, 02:41 PM   #3
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Information on compatibility for second gen cars is a little hard for me to find, with most suppliers and manufacturers not listing lightened flywheels, clutches of kits for the second generation, 2022+ GR86 or BRZ.
As mentioned, Ogura Racing Clutch (ORC) in Japan lists clutches with the same part number for both gens but it does not list or combine a flywheel and clutch as a kit from what I can tell.
CSG shows a single disc ACT clutch kit, SB8-XTSS, but ACT says there isn't anything for second gen cars.
Same for the OS Giken clutch they list. OS Giken doesn't list it, or any as fitting second gen cars.
Is anyone familiar with what is different and why some sell them for gen2 and most don't.
Scargod is offline   Reply With Quote
Old 01-11-2025, 05:31 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
FWIW: On my swap, I used my stock FA20 clutch components on my FA24.
In his newer version of the swap kit, RS Mtrs is going to use the FA24 crank trigger with a Prius sensor. I don't know if this changes which flywheel you would use.
FS - OS Giken HTR Clutch / Flywheel (Single Plate Clutch) SCAL dakine001 Transmission and Driveline 2 03-11-2024 01:56 PM
SOLD OS Giken HTR Clutch / Flywheel (Single Plate Clutch) RedReplicant Transmission and Driveline 0 02-27-2022 05:56 PM
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? OICU812 Engine, Exhaust, Transmission 2 05-17-2014 01:56 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
