Old 05-23-2022, 03:20 PM   #1
WheelrDealer
WheelrDealer's Avatar
Drives: 2016 FR-S
Looking for some Tuner Support '17 86 SCCA T4
I thought I would ask. I have a T4 SCCA car that is required to run a stock header, less CAT and a 55mm restrictor. Prior to starting my SCCA Novice Driving permit I ran an unequal length header. I bought a tune with my ECUTek OBD, license and ProECU. I never flashed the Delicious Tune and the car is running on a stock tune. I need to get in contact with a tuner that can sell/build me a baseline tune for a US BRZ Manual 2017 ZA1K10C or compatible. I have a 20 minute idle log and two logs at speed on the track to review.
All I need is Rev-cut set at 7,650 and Auto Blip plus compensation for the restrictor. My throttle response is poor since the restrictor/exhaust install. I am reaching out because I have a test and tune Wed. the 25th, SCCA practice on 27th and a race weekend 28-29th. I have talked to some tuners but they can't get to me until June.
Compatible ROM Files:
US BRZ Manual 2017 ZA1JK00C, ZA1JK10C, ZA1JV00C00G, ZA1JS00C and ZA1JS10C
Any help or advice is appreciated.
Thanks,
Bill
Wheelrdealer Racing
WheelrDealer is offline   Reply With Quote
Old 05-23-2022, 05:17 PM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Zach at CSG has been great with me.
Initial communication in December and his initial 94 tune came within days of online order/payment.
Subsequently, my return logs were promptly answered with revised tunes over-night until complete. In total 5 maps got us done. ����
Last week we where in touch and he sent me a second map for 91 to be used when 94 was un-available. Which is common away from the populated areas in Ontario.
Muskoka800 is offline   Reply With Quote
Old 05-23-2022, 06:49 PM   #3
WheelrDealer
Drives: 2016 FR-S
Just contacted him and his assistant Jasmin sent me everything to get started. He will expedite my base tune to me for a small additional fee. That is fine with me. Thanks for the referral.
BR
Wheelrdealer Racing
Old 05-24-2022, 09:41 AM   #4
Muskoka800
BR
I’m confident you will be pleased with this choice.
Happy Motoring!
Old 07-23-2022, 08:58 AM   #5
WheelrDealer
Drives: 2016 FR-S
Happy Motoring!
Thought I would follow up on my experience with Zach as CSG. Zach worked with me and my tune to get it just right. I am really happy with his attention to detail and service. Let me say I did not make it easy on him. I bricked my ecu at the race track and worked with Zach and eventually Chris Todd at ECUTek to get the stock tune loaded again. It turns out the CANbus switches I use to put the car in track mode and turn the radiator fans interfere with flashing the stock tune. As soon as Chris suggested I unplug the CANbus switches everything flashed as it should. My car is a full race T4 with most of the factory switches either removed or zip tied behind the dash. With no E brake I use the CANbus switch to execute the peddle dance. Anyway I digress, Zach and Chris did a great job supporting the ECUTek product. Thank you for the suggestion.
Wheelrdealer Racing
The Following 4 Users Say Thank You to WheelrDealer For This Useful Post:
bcj (07-23-2022), CSG Mike (07-25-2022), DocWalt (07-28-2022), Lonewolf (07-24-2022)
Old 07-23-2022, 11:23 AM   #6
jflogerzi
jflogerzi's Avatar
Zach is one of the best out there. He does good work. Happy with his tune on my tired almost 90k mile motor
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Oi Takashi in USA, driving for Import Tuner Magazine FRS tuner impressions. Moto-P Scion FR-S / Toyota 86 GT86 General Forum 15 11-19-2015 04:39 PM
A thank you for your support CSG Mike Tracking / Autocross / HPDE / Drifting 10 05-03-2014 12:34 PM
IOS 6 MAP Support w/BRZ HU xwd Electronics | Audio | NAV | Infotainment 19 10-04-2013 07:15 PM
ID3 Support RMStringer Electronics | Audio | NAV | Infotainment 0 01-21-2013 09:55 PM
Lachute Performance & EcuTeK support SWAG Racing for the FR-S Tuner Challenge Edition Cotnoir Scion FR-S / Toyota 86 GT86 General Forum 2 01-16-2013 02:35 PM
