Old 05-21-2022, 01:14 PM   #1
IsaiahW
IsaiahW's Avatar
Drives: 2013 Subaru brz limited
Broke down
Car shut off while driving and wont start i dont have any ecu codes what could be the issue
IsaiahW is offline   Reply With Quote
Old 05-21-2022, 01:20 PM   #2
Ashikabi
Ashikabi's Avatar
Could be a lot of things. Does it crank? Try to start? Fuel? Spark?
Old 05-21-2022, 01:22 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
do you have a key for it? does the car exist? does the battery exist?
Old 05-21-2022, 01:25 PM   #4
IsaiahW
IsaiahW's Avatar
It cranks but no start i have fuel but I believe it just wont spark could my ecu be fried? It is 98 degrees where im at today
Old 05-21-2022, 01:40 PM   #5
IsaiahW
IsaiahW's Avatar
The thing thats making it difficult is that it doesnt have any codes i have stock key which is good battery level is good
Old 05-21-2022, 01:41 PM   #6
Ashikabi
Ashikabi's Avatar
Let's slow down there bro. 98 degrees is not a significant number for a computer. Remember they drive these things in Qatar.
Always start with the cheapest thing first. When you turn the key on, can you hear your fuel pump come on? If so, you can rule out the fuel pump for the first round of testing. Check every fuse, including under hood. If you spray a little brake cleaner/starting fluid in the intake while cranking, does it try to start? If it fires then you have spark. If the fuel pump runs and you have spark, then the fuel injectors are the most likely culprit
Old 05-21-2022, 02:13 PM   #7
soundman98
soundman98's Avatar
did you recently get gas?
Old 05-21-2022, 02:47 PM   #8
IsaiahW
IsaiahW's Avatar
Fuel pump good ill check the other stuff im disconnecting negative terminal for like 5 minutes at this point imma try everything ill send my tuner a crank log hopefully that somewhat helps to check the injection sparks and/or coils
Old 05-21-2022, 02:48 PM   #9
IsaiahW
IsaiahW's Avatar
Naw
Old 05-21-2022, 05:26 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Hold the gas pedal 100% down and crank. Let off the gas if it starts to start obviously.
My car did this when IATs were super hot, there's a fuel compensation table that may need to be adjusted
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 05-21-2022, 06:03 PM   #11
Ashikabi
Ashikabi's Avatar
It got so rich it died?
Old 05-21-2022, 06:08 PM   #12
IsaiahW
IsaiahW's Avatar
I believe i found the issue my fuel level sensor must of went out or got caught up in the wire inside the tank man ya boy was dry of fuel lol i waste money on a damn tow when i was right by a gas station lol
Old 05-21-2022, 06:11 PM   #13
DarkPira7e
DarkPira7e's Avatar
Well, for the no start. No idea why it stalled, one issue at a time.
Seems like he was out of gas anyway
Rocker arm broke and broke my valve cover... j0hnnykthx Issues | Warranty | Recalls / TSB 9 08-07-2020 08:12 AM
Key Fob broke down RichardsFRS Scion FR-S / Toyota 86 GT86 General Forum 10 12-29-2015 04:38 PM
This is why I'm broke cdrazic93 Off-Topic Lounge [WARNING: NO POLITICS] 14 07-26-2014 03:15 PM
I think I broke the tie rod....... jshum Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 06-04-2014 12:41 AM
Oh-Oh's, I Think I Broke It! track_warrior Issues | Warranty | Recalls / TSB 232 06-12-2013 10:58 PM
