Drives: Gr86
Camber plate recommendations
Looking for recommendations for camber plates to go along with a set of RaceComp Tarmac 2 coilovers.
What does everyone use? |
We're pretty darn happy with the Vorshlag camber plates paired with Tarmac 2s.
- Andrew |
Drives: 2016 BRZ
| The Following User Says Thank You to Joon525 For This Useful Post: | Racecomp Engineering (05-20-2022) |
Drives: Toyota 86
My vote goes to Kw, for two reasons:
1) Reliability, since they’re the only plates with a dust boot which cover the bottom part preventing debris and dust to come inside the spherical. 2) Design: they roughly add 15mm of bump travel and the plastic collar between the upper spring perch and the bottom part of the spherical case makes everything super silent and smooth while the strut is turned. Kw doesn’t sell the pillow ball as a replacement but you can easily buy one from Rodobal. |
Drives: Gr86
Thanks for the advice on the Vorshlags. I noticed they are the most expensive top hats I’ve seen paired with Coilovers for the GR86/BRZs. I figured there might be respectable less expensive options.
#6 | |
- Andrew |
Drives: Toyota 86
Ups, sorry I didn’t know.
Drives: 2013 BRZ Sport-Tech
I think I originally planned to get raceng plates but due to time/cost I wound up getting Verus camber plates instead. They've been on the car for a couple of years, including winter driving, with no issues yet.
Vorshlag plates were just too expensive and longer shipping/lead time than I was working with at the time. |
| The Following User Says Thank You to CrowsFeast For This Useful Post: | Racecomp Engineering (05-20-2022) |
Drives: GR86 2022
Get a set of rce superstreet, save the shocks as backup/down time during rebuild/off season driving etc. That is basically what I did. I used roughly a dozen different camber plates and those KWs is the most I liked.
#10 | |
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Kulebrero1 (05-24-2022) |
#11 |
Drives: 2020 toyota 86
Another vote for Verus
| The Following User Says Thank You to 54fighting For This Useful Post: | Kulebrero1 (05-24-2022) |
#12 |
#13 |
Drives: Gr86
#14 |
| Camber plate increments. | gen3v8 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 05-19-2022 10:28 PM |
| FS: KW V3 with Camber plate | ChaosTheSlayer | Brakes, Suspension, Chassis | 6 | 08-22-2019 12:10 AM |
| This is how camber affects toe in front. Also RCE camber plate info. | Pat | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 05-04-2016 10:08 PM |
| Issue with camber plate | ZionsWrath | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 08-02-2015 05:04 PM |
| Jrz rs1 no camber plate? | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 09-09-2014 10:16 PM |
