Old 05-11-2022, 08:01 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Powertrain options for track only
I have a track only BRZ with a tired motor and trans on its last leg. I got plenty of time out of it, so it's time for a powertrain refresh.
All I really care about is reliability and then cost.
I'd rather pay more for more reliability, to a reasonable degree.
Increased power isn't much of a goal, if any.
So what does everyone recommend here? And where should I get it from?
What year engines will be compatible? I have an early 2014, and it has the 2013.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 05-11-2022, 08:37 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
Best reliability would be to swap in a stock Honda K24 or a Ls motor.
Jdmjunkie is offline   Reply With Quote
The Following 3 Users Say Thank You to Jdmjunkie For This Useful Post:
DarkPira7e (05-12-2022), GrandSport (05-12-2022), soundman98 (05-12-2022)
Old 05-12-2022, 09:08 AM   #3
GrandSport
GrandSport's Avatar
That’s a lot more than I care to get into and this trans doesn’t need more power. I’d just buy a c5 race car at that point.
Old 05-12-2022, 09:43 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Look at Element Tuning in Fla.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 05-12-2022, 09:59 AM   #5
GrandSport
GrandSport's Avatar
What year transmissions can I use? Is it just the gearing that changed?
Old 05-12-2022, 11:11 AM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
What’s your budget
Old 05-12-2022, 11:32 AM   #7
GrandSport
GrandSport's Avatar
Originally Posted by TommyW View Post
What’s your budget
I guess it depends. I figure I can get a new bottom end for around $2k. It’s the heads and trans that I haven’t much looked at lately.
Old 05-12-2022, 12:29 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you are happy with it just throw another shortblock at it and call it a day. Maybe add an oil pan baffle for some extra protection.
I am going through this now. Want a K swap, can't justify the cost yet. I'm just going to do a leak down and comp test, tear it down and check the rod and main bearings. Replace what needs replaced and send it.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 05-12-2022, 02:26 PM   #9
TommyW
TommyW's Avatar
You can have the heads re done. I went with an IAG shortblock for good measure.
The Following User Says Thank You to TommyW For This Useful Post:
Old 05-12-2022, 03:43 PM   #10
GrandSport
GrandSport's Avatar
Mine is smoking a good bit and my mph/lap times are down about 4 seconds too. Pretty sure I'm on borrowed time at this point.
I can't imagine I'd really need aftermarket internals for stock power, but what did that run you?
It's really shocking how expensive a low mile long block is. I thought for sure I'd be able to grab a 30k mile crate for like $3k. More like double that for double the miles.
Anyone know what year engines and transmissions I can use?
Old 05-12-2022, 05:10 PM   #11
RedReplicant
Drives: None
Transmissions are effectively the same across all years
Long block can be used across all years, but you will need to swap a few things from your old motor depending on year. There are some threads around here if you search the motor year you're swapping and the base year.
I would personally not touch a motor that has been opened by anyone since it left the factory on these cars since they are already kind of hand grenades, but your mileage my vary. I went K24 and sold my 30k-ish mile motor as a long block for $3k.
I think prices for these motors are higher than expected because they effectively only came in BRZ/FRS/86, cutting the donor pool significantly.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
kevaughan (06-11-2022), NoHaveMSG (05-12-2022)
Old 05-12-2022, 08:32 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I been down that road. Got an engine from a "master" Toyota tech. It was a mess. Threw a rocker but don't think I can attribute that to his work but the FIPG job he did was awful, he must have used 2 full tubes of it on that thing. It wasn't going to be long of this world.
RedReplicant (05-13-2022)
Old 05-12-2022, 11:42 PM   #13
TommyW
TommyW's Avatar
it was 3,200. They also machine the block for better oiling. Way better bearings than stock also. I wanted bulletproof. Lol I call it my Toyota boxter. Overengineered like a Toyota motor.
Old 05-29-2022, 07:04 PM   #14
GrandSport
GrandSport's Avatar
So as an update, I couldn't find a better option than just a straight up new crate bottom end. I guess that it's hard to argue with +100 hard track hrs for $5k- maybe even 200 come to think of it.
As far as transmissions go, there seems to be an issue with McCloud clutches not 100% disengaging and killing synchronizers. Going to switch out something else and try again.
The Following User Says Thank You to GrandSport For This Useful Post:
blsfrs (05-29-2022)
Transmission upgrade options for stock power and track only use? GrandSport Tracking / Autocross / HPDE / Drifting 46 02-24-2021 06:57 PM
UEL+track pipe too loud - single left exhaust options? Wiscocrashtest Engine, Exhaust, Transmission 11 09-12-2018 02:33 PM
Quieter (<93db) track muffler options for header/single hi-flow cat dp1 Engine, Exhaust, Transmission 37 07-04-2016 10:02 PM
Headers and Powertrain Warranty? smg1138 Engine, Exhaust, Transmission 5 07-27-2015 02:27 PM
Powertrain Durability/ Longetivty regal Scion FR-S / Toyota 86 GT86 General Forum 5 05-11-2013 04:57 PM
