Old 05-11-2022, 07:01 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Powertrain options for track only
I have a track only BRZ with a tired motor and trans on its last leg. I got plenty of time out of it, so it's time for a powertrain refresh.
All I really care about is reliability and then cost.
I'd rather pay more for more reliability, to a reasonable degree.
Increased power isn't much of a goal, if any.
So what does everyone recommend here? And where should I get it from?
What year engines will be compatible? I have an early 2014, and it has the 2013.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 05-11-2022, 07:37 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
Best reliability would be to swap in a stock Honda K24 or a Ls motor.
Jdmjunkie is offline   Reply With Quote
The Following 3 Users Say Thank You to Jdmjunkie For This Useful Post:
DarkPira7e (05-12-2022), GrandSport (05-12-2022), soundman98 (05-11-2022)
Old 05-12-2022, 08:08 AM   #3
GrandSport
GrandSport's Avatar
That’s a lot more than I care to get into and this trans doesn’t need more power. I’d just buy a c5 race car at that point.
Old 05-12-2022, 08:43 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Look at Element Tuning in Fla.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 05-12-2022, 08:59 AM   #5
GrandSport
GrandSport's Avatar
What year transmissions can I use? Is it just the gearing that changed?
Old 05-12-2022, 10:11 AM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
What’s your budget
TommyW is offline   Reply With Quote
Old 05-12-2022, 10:32 AM   #7
GrandSport
GrandSport's Avatar
Originally Posted by TommyW View Post
What’s your budget
I guess it depends. I figure I can get a new bottom end for around $2k. It’s the heads and trans that I haven’t much looked at lately.
Old 05-12-2022, 11:29 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you are happy with it just throw another shortblock at it and call it a day. Maybe add an oil pan baffle for some extra protection.
I am going through this now. Want a K swap, can't justify the cost yet. I'm just going to do a leak down and comp test, tear it down and check the rod and main bearings. Replace what needs replaced and send it.
Old 05-12-2022, 01:26 PM   #9
TommyW
TommyW's Avatar
You can have the heads re done. I went with an IAG shortblock for good measure.
The Following User Says Thank You to TommyW For This Useful Post:
Old 05-12-2022, 02:43 PM   #10
GrandSport
GrandSport's Avatar
Mine is smoking a good bit and my mph/lap times are down about 4 seconds too. Pretty sure I'm on borrowed time at this point.
I can't imagine I'd really need aftermarket internals for stock power, but what did that run you?
It's really shocking how expensive a low mile long block is. I thought for sure I'd be able to grab a 30k mile crate for like $3k. More like double that for double the miles.
Anyone know what year engines and transmissions I can use?
Old 05-12-2022, 04:10 PM   #11
RedReplicant
Drives: None
Transmissions are effectively the same across all years
Long block can be used across all years, but you will need to swap a few things from your old motor depending on year. There are some threads around here if you search the motor year you're swapping and the base year.
I would personally not touch a motor that has been opened by anyone since it left the factory on these cars since they are already kind of hand grenades, but your mileage my vary. I went K24 and sold my 30k-ish mile motor as a long block for $3k.
I think prices for these motors are higher than expected because they effectively only came in BRZ/FRS/86, cutting the donor pool significantly.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
kevaughan (06-11-2022), NoHaveMSG (05-12-2022)
Old 05-12-2022, 07:32 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I been down that road. Got an engine from a "master" Toyota tech. It was a mess. Threw a rocker but don't think I can attribute that to his work but the FIPG job he did was awful, he must have used 2 full tubes of it on that thing. It wasn't going to be long of this world.
RedReplicant (05-12-2022)
Old 05-12-2022, 10:42 PM   #13
TommyW
TommyW's Avatar
it was 3,200. They also machine the block for better oiling. Way better bearings than stock also. I wanted bulletproof. Lol I call it my Toyota boxter. Overengineered like a Toyota motor.
Old 05-29-2022, 06:04 PM   #14
GrandSport
GrandSport's Avatar
So as an update, I couldn't find a better option than just a straight up new crate bottom end. I guess that it's hard to argue with +100 hard track hrs for $5k- maybe even 200 come to think of it.
As far as transmissions go, there seems to be an issue with McCloud clutches not 100% disengaging and killing synchronizers. Going to switch out something else and try again.
The Following User Says Thank You to GrandSport For This Useful Post:
blsfrs (05-29-2022)
Transmission upgrade options for stock power and track only use? GrandSport Tracking / Autocross / HPDE / Drifting 46 02-24-2021 05:57 PM
UEL+track pipe too loud - single left exhaust options? Wiscocrashtest Engine, Exhaust, Transmission 11 09-12-2018 01:33 PM
Quieter (<93db) track muffler options for header/single hi-flow cat dp1 Engine, Exhaust, Transmission 37 07-04-2016 09:02 PM
Headers and Powertrain Warranty? smg1138 Engine, Exhaust, Transmission 5 07-27-2015 01:27 PM
Powertrain Durability/ Longetivty regal Scion FR-S / Toyota 86 GT86 General Forum 5 05-11-2013 03:57 PM
