Old 05-07-2022, 09:51 AM   #1
all4spl
FS: evo x brembo brake conversion kit
These are refurbished evo x calipers that have been rebuilt and powder coated red. All seals are new and reassembled with the correct sized spacers and hardware required for mounting. Only thing you need are brake pads. Looking for $600 shipped
all4spl is offline   Reply With Quote
Old 05-07-2022, 10:33 AM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
These work well with the CTS upgrade up front.
Muskoka800 is offline   Reply With Quote
Old 05-09-2022, 10:38 AM   #3
GabeoHuncho
Drives: 2013 FR-S Vortech V3
Very tempting.
Pardon my ignorance, but would these bolt in with standard lines and fasteners?
GabeoHuncho is offline   Reply With Quote
Old 05-09-2022, 05:06 PM   #4
all4spl
Originally Posted by GabeoHuncho View Post
Very tempting.
Yes they will!
Old 05-09-2022, 06:07 PM   #5
Muskoka800
Actually, the lines are fine but you must drill out the OEM caliper mounting holes and use the larger STI caliper bolts. If memory serves the stock bolts are 6mm while the EvoX caliper bolt holes are 8mm. Any easy change with an 8mm drill bite and STI 8mm rear caliper bolts.
The Following User Says Thank You to Muskoka800 For This Useful Post:
all4spl (05-11-2022)
Old 05-10-2022, 10:52 AM   #6
SpeBud07
Drives: 2013 FRS
Interested, PM sent
SpeBud07 is offline   Reply With Quote
Old 05-11-2022, 10:09 AM   #7
all4spl
Originally Posted by Muskoka800 View Post
Actually, the lines are fine but you must drill out the OEM caliper mounting holes and use the larger STI caliper bolts. If memory serves the stock bolts are 6mm while the EvoX caliper bolt holes are 8mm. Any easy change with an 8mm drill bite.
Perhaps you could find 6mm-8mm sleeves and use your stock bolts.
Sorry about that. I didn't get this far, these are fresh fresh and havent been installed yet.
Old 06-06-2022, 12:06 PM   #8
all4spl
Bring this up!
Old 07-11-2022, 10:11 AM   #9
all4spl
bring this up.
Old 07-26-2022, 01:22 PM   #10
all4spl
to the top.
Old 08-03-2022, 09:57 AM   #11
all4spl
Bring it up.
Old 08-11-2022, 09:09 AM   #12
all4spl
Lets get these sold.
Old 08-24-2022, 12:40 PM   #13
all4spl
bring this up
Old 09-19-2022, 10:09 AM   #14
all4spl
Bump this up!
Brembo conversion problem mrha Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 01-29-2016 01:44 AM
2002-2006 STI Brembo Conversion BobbyDee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-15-2015 11:16 AM
Brembo STI Brake for BRZ cslntuee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 10-22-2014 02:25 AM
