Old 05-01-2022, 01:22 AM   #1
repillows
Drives: 2013 Scion Frs
Power steering failure
My power steering quit working and is showing a current code of C1528 which is motor rotation angle sensor. This issue was mostly intermittent but has recently been happening a lot. I tried unplugging the harnesses going to the power steering ECU with no luck, and looking at live data, the rotation angle is all over the place and is showing little to no amps to the motor. The vehicle had an alignment issue with the power steering working when I bought it but then stopped. I replaced the struts, control arms, and steering rack to fix the alignment issue thinking that the power steering issue was related but it was not. Has anybody experienced this issue or has any insight as to what to do? Thanks!
repillows is offline   Reply With Quote
Old 05-01-2022, 08:40 AM   #2
Ashikabi
Ashikabi's Avatar
I've never had it quit working but I did have the angle wrong when reattaching the rack and it lit up my dash. I knew right away what the issue was cuz my steering wheel was pretty crooked. Reattached the rack and lights went away. Not sure if that anecdote will be useful to you or not
Old 05-01-2022, 11:26 AM   #3
repillows
I had that issue too when I installed my steering rack causing slip light and ABS light because of the steering angle sensor. Centered the rack and no lights for that. Only power steering light and failure
Old 05-03-2022, 01:51 AM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
This is a purely electrical issue. I've never seen this one in particular but it boils down to one of three things.
  1. The resolver,
  2. The control unit,
  3. Or one of the four wires between them.
Ok, that's six things but you get what I mean. Gun to my head, I'd start with the resolver. Moving parts, brushes, slip rings... but if that was the case, I feel like we should've heard about this before now, and more often.
POWER ASSIST SYSTEMS: POWER STEERING SYSTEM: C1528; Motor Rotation Angle Sensor Malfunction; 2013 MY FR-S [03/2012 - ]
bcj (05-03-2022)
2013 Subaru BRZ -- Another Power Steering Failure & Troubleshooting Help BrettRS Issues | Warranty | Recalls / TSB 43 10-08-2025 12:19 PM
Electric power steering and steering column part info raspec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-12-2021 05:27 PM
Power steering failure and code issues RyanOlsen05 Scion FR-S / Toyota 86 GT86 General Forum 1 09-18-2021 12:46 AM
Power Steering rosol16 Issues | Warranty | Recalls / TSB 15 12-15-2015 09:44 AM
Electronic Power Steering Failure tjdiz92 Issues | Warranty | Recalls / TSB 17 06-18-2014 01:34 AM
