GoPro 10 settings
Given that GoPros are popular for autocross/track video, I went out and bought a new 10 on sale, as the 10 was only about $50 more than an 8 with the discount. I have a headrest mount, and put it on there for an event.
Let's just say the video is terrible, the outside is wildly overexposed. I looked up some fixes for that and tried again, but it really hasn't made things much better. Now, I know other folks have made this work well, could you share your settings? Older ones may offer some clues too, so please post what you have that you're happy with. Thanks.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
Drives: 22 BRZ limited
Could you post some sample video? I'm curious to see what it looks like.
Drives: Nevermorange FRS
Turn your exposure down or set it to spot exposure (or both). I have my EV on -2. Spot Exposure (if the 10 has it) will have the camera properly expose the shot based on a narrow defined spot (like outside the windshield) instead of trying to expose the whole shot (like the majority if the frame which is dark which is the inside of your car).
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | bcj (04-26-2022) |
#4 | |
Maybe after next event if I can get the video part a little better. As for the driving, I'll give my driving a stern talking to later this week about sucking less
No worries. I'm looking to borrow a Hero 8 so I can practice capturing my terrible driving. I'll post it up here when I do it.
#6 | |
Your settings should remain. Mine does. Secondly, the one touch turn on + record setting is great for this use case.
PRO86 | WTCC | STL
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
Agreed, -2 EV worked better when I tried, but I still preferred my older DJI Mimo Action cam's video quality, and got back to it.
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
Thanks for the tips, the video is better, though still not great. I'll look over the settings again, but at least I got something useful. Pretty sure this is at 1080P/30FPS/-2 EV.
#10 | |
Drives: GR86
Do a few tests even at home not around a track. I think you'll find -1.5EV is all you need. -2 is too underexposed, but at least you can see the outside! |
| The Following User Says Thank You to gcmak For This Useful Post: | Autoxer62 (05-03-2022) |
#11 |
Depending on software- you can change exposure in post. You can fix underexposed, not so much overexposed.
PRO86 | WTCC | STL
#12 | |
![]() I'll try dialing back to 1.5 per gcmak and see how that looks. One other thing, is it my imagination or is the video just generally blurry? I don't see any obvious thumbprints on the lens, so that's not it.
#13 | |
Drives: GR86
If you're using pro mode, you could try to increase the sharpening (though I know that's not necessarily going to address what you're seeing). |
#14 |
So I sorted out my problem of the videos being blurry.
In short, "Bryan is an idiot" ![]() You may recall the GoPro is new. So is the protective case. I went to clean the lens and the case carefully and found a big ol' thumbprint on the case over the lens. Then I realized I missed removing the clear protective film on the case. ![]() For anyone else using a newer GoPro I did find one other setting to use, and that's to turn on Landscape Lock. The below vid from this past weekend's NJ Pro looks pretty good now, so feel free to comment on my crappy driving rather than the lousy video The settings are 1080P/30FPS/-1.5 EV/Narrow/Landscape Lock
| BC coilovers settings | BlOody_BoOger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 02-14-2021 12:21 PM |
| Gopro settings | Chen | Northwest | 0 | 04-18-2014 02:43 PM |
| BRZ EQ Settings | Marcoscrdo | Electronics | Audio | NAV | Infotainment | 1 | 01-02-2013 04:35 PM |
| Settings for TCS and AT | atledreier | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-20-2012 09:36 AM |
| EQ settings | chadz | Electronics | Audio | NAV | Infotainment | 2 | 07-15-2012 09:18 PM |
