Drives: 22 BRZ limited
Track data recording
Is there a better app out there for Android besides Torque pro for datalogging basic OBD-II data? The autocross sessions here are pretty short and probably don't need to record data, but I would like to try to dip my toe into data collection before I get to actual track time and better data systems.
Drives: Crapcan
I use racechrono, but primarily for timing. It can log a good amount of OBD data too.
I'll take a look at it. Thanks!
There's not really a middle ground, you either spend <$100 and it's a little janky or you jump up to >$200 to SoloStorm or AIM.
Lots to be gained in getting autox data if you want to be competitive there, SoloStorm is great. |
Drives: LP DSP / CSP '13 BRZ
I tried a lot of free apps and couldn’t find one that did what I wanted and went to SoloStorm and it’s awesome and also works on track.
Then once I got used to it and wanted even more data I paired the solostorm with a RaceCapture and it’s amazing. |
Drives: Crapcan
Honestly, I am happier with Racechrono, an XGPS160 and MX+ OBD link then with my Aim. The aim has some nice features but it's buggy sometimes. I get pretty good data from racechrono. And the battery in my Solo2 died not even two years old. It was always a bit dodgy and never held a charge well even when new.
Drives: 2017 BRZ series.yellow
TrackAddict works quite well considering it's free.
Just pair with the proper blutooth ODBII module and an external GPS. |
Drives: 2022 GR86
I like Trackaddict for the track (as far as free stuff goes), paired with a Qstarz or XGPS160 it is just as accurate as my transponder. That's what I use on my TT4 BMW for time attack.
For autocross, Solostorm for sure, with same GPS. Add on a Bluetooth OBDII adapter if you want the extra info.
#10 | |
AIM Solo 2 DL for anything else. |
#11 | |
G-force readings from the phone. Position and speed from the external gps. A Garmin Glo 2 GoPro Hero 5 black for video with an external mic mounted to the rear license plate frame. Data and video put together with RaceRender 3 (also free) Here is an example of it all put together. |
#12 |
Drives: 2018 BRZ
Is there a real benefit of an external GPS? I would have guessed the phone's internal GPS would be fine. Or does the external GPS offer faster refresh rate than 1 Hz?
#13 |
#14 |
I used my phone's internal gps for a bit, then switched to an external. The phone GPS was WAY off. Speeds were wrong and lines were wrong. They don't update nearly fast enough or accurate enough. I could easily see each individual point of data collection on Trackaddict. There were large gaps between data points, made the line all angular and incorrect.
| Fs racecapture track data logger system -SOLD- | redlined600 | Audio/Visual, Electronics, Infotainment, NAV | 0 | 07-07-2018 03:14 PM |
| Data acquisition system to try during track days | mabviper | CANADA | 40 | 09-12-2017 03:15 PM |
| Track Data Logs! | DarkSunrise | Software Tuning | 31 | 07-10-2017 02:56 PM |
| How about we make a track tire data thread? | ddeflyer | Tracking / Autocross / HPDE / Drifting | 0 | 06-09-2014 01:25 PM |
| iPhone track data logger app? | Wonderbar | Tracking / Autocross / HPDE / Drifting | 14 | 05-07-2013 03:31 PM |
