Old 04-25-2022, 08:14 AM   #1
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Track data recording
Is there a better app out there for Android besides Torque pro for datalogging basic OBD-II data? The autocross sessions here are pretty short and probably don't need to record data, but I would like to try to dip my toe into data collection before I get to actual track time and better data systems.
Old 04-25-2022, 11:29 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I use racechrono, but primarily for timing. It can log a good amount of OBD data too.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
dragoontwo (04-25-2022), timurrrr (05-03-2022)
Old 04-25-2022, 01:10 PM   #3
dragoontwo
dragoontwo's Avatar
I'll take a look at it. Thanks!
Old 04-25-2022, 05:00 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
There's not really a middle ground, you either spend <$100 and it's a little janky or you jump up to >$200 to SoloStorm or AIM.
Lots to be gained in getting autox data if you want to be competitive there, SoloStorm is great.
ineedyourdiddly
Old 04-25-2022, 05:24 PM   #5
Eric1855
Drives: LP DSP / CSP '13 BRZ
I tried a lot of free apps and couldn’t find one that did what I wanted and went to SoloStorm and it’s awesome and also works on track.
Then once I got used to it and wanted even more data I paired the solostorm with a RaceCapture and it’s amazing.
Eric1855 is offline   Reply With Quote
The Following User Says Thank You to Eric1855 For This Useful Post:
strat61caster (04-25-2022)
Old 04-25-2022, 05:27 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Honestly, I am happier with Racechrono, an XGPS160 and MX+ OBD link then with my Aim. The aim has some nice features but it's buggy sometimes. I get pretty good data from racechrono. And the battery in my Solo2 died not even two years old. It was always a bit dodgy and never held a charge well even when new.
strat61caster (04-25-2022), timurrrr (05-03-2022)
Old 04-25-2022, 11:35 PM   #7
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
TrackAddict works quite well considering it's free.
Just pair with the proper blutooth ODBII module and an external GPS.
Breezio is offline   Reply With Quote
Old 04-26-2022, 01:07 AM   #8
macuser27
macuser27's Avatar
Just curious. What do you log with your OBD2 module and TrackAddict?
Thanks.
macuser27 is offline   Reply With Quote
Old 04-26-2022, 12:52 PM   #9
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I like Trackaddict for the track (as far as free stuff goes), paired with a Qstarz or XGPS160 it is just as accurate as my transponder. That's what I use on my TT4 BMW for time attack.
For autocross, Solostorm for sure, with same GPS.
Add on a Bluetooth OBDII adapter if you want the extra info.
justinco is offline   Reply With Quote
Old 04-26-2022, 04:33 PM   #10
CSG Mike
CSG Mike's Avatar
Solostorm for AutoX.
AIM Solo 2 DL for anything else.
Kelse92 (04-26-2022)
Old 04-26-2022, 11:26 PM   #11
Breezio
Breezio's Avatar
Thanks.
I use an ODBlink MX+ and mainly use it for RPM and throttle position. Sometimes gear position as well.
G-force readings from the phone.
Position and speed from the external gps. A Garmin Glo 2
GoPro Hero 5 black for video with an external mic mounted to the rear license plate frame.
Data and video put together with RaceRender 3 (also free)
Here is an example of it all put together.
The Following User Says Thank You to Breezio For This Useful Post:
macuser27 (04-27-2022)
Old 04-27-2022, 08:37 AM   #12
Ohio Enthusiast
Drives: 2018 BRZ
Is there a real benefit of an external GPS? I would have guessed the phone's internal GPS would be fine. Or does the external GPS offer faster refresh rate than 1 Hz?
Old 04-27-2022, 08:49 AM   #13
dragoontwo
dragoontwo's Avatar
The external GPS that solostorm suggests is 10Hz refresh.
The Following User Says Thank You to dragoontwo For This Useful Post:
Ohio Enthusiast (04-27-2022)
Old 04-27-2022, 09:06 AM   #14
Breezio
Breezio's Avatar
I used my phone's internal gps for a bit, then switched to an external. The phone GPS was WAY off. Speeds were wrong and lines were wrong. They don't update nearly fast enough or accurate enough. I could easily see each individual point of data collection on Trackaddict. There were large gaps between data points, made the line all angular and incorrect.
The Following 2 Users Say Thank You to Breezio For This Useful Post:
Ohio Enthusiast (04-27-2022), timurrrr (05-03-2022)
Fs racecapture track data logger system -SOLD- redlined600 Audio/Visual, Electronics, Infotainment, NAV 0 07-07-2018 03:14 PM
Data acquisition system to try during track days mabviper CANADA 40 09-12-2017 03:15 PM
Track Data Logs! DarkSunrise Software Tuning 31 07-10-2017 02:56 PM
How about we make a track tire data thread? ddeflyer Tracking / Autocross / HPDE / Drifting 0 06-09-2014 01:25 PM
iPhone track data logger app? Wonderbar Tracking / Autocross / HPDE / Drifting 14 05-07-2013 03:31 PM
