Old 04-23-2022, 11:32 PM   #1
Kulebrero1
Drives: Gr86
Coilovers and springs for tack duty
Looking for recommendations on coilovers for track duty for a GR86. I prefer my suspension on the stiffer side, but not rock solid…I still have to drive it to/from the track.
What are you using?
Kulebrero1 is offline   Reply With Quote
Old 04-23-2022, 11:49 PM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Budget?
RCE SS1 and CSG flex A are good street/track coils.
RCE does tamrac Clubsport for track focused setup.
949 racing does XIDA Coilovers if you want to ball with 4k setup.
Old 04-25-2022, 12:08 AM   #3
Evil Rocky
Drives: FRS
Following. Time to change my current coilovers. Want something more for track. I occasionally drive it around town. But mostly track car.
Evil Rocky is offline   Reply With Quote
Old 04-26-2022, 08:49 AM   #4
Racecomp Engineering
What size and what type of tire do you use?
- Andrew
Old 04-26-2022, 10:20 AM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
- Andrew
Does it make that much of a difference between 17 or 18 inch tires as long as they are close to stock circumference? Does wider tread make that big a difference?
dragoontwo is offline   Reply With Quote
Old 04-26-2022, 10:42 AM   #6
Mostly asking about tire width here, but the the tire type (compound) makes more of a difference than width anyway.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
dragoontwo (04-26-2022), NoHaveMSG (04-26-2022)
Old 04-26-2022, 04:34 PM   #7
What are you using?
Can you elaborate on why you prefer stiffer?
Old 04-28-2022, 09:33 PM   #8
Kulebrero1
Drives: Gr86
Originally Posted by RToyo86 View Post
Budget?
$2k or so.
What spring rates do people run on track cars?
The 949 Xida page says 500/500. Goodwin racing offers 400/350. I thought you’re supposed to run a higher rate in the rear because of the suspension geometry. 400-500 sounds low as well.
Not sure where to go to learn more.
Old 04-28-2022, 09:35 PM   #9
Kulebrero1
Drives: Gr86
- Andrew
I plan to run 17x8 wheels with 245/40/17 or 225/45/17, RS4s…or some other 200TW tire.
Old 04-28-2022, 09:49 PM   #10
Kulebrero1
Drives: Gr86
I don’t know…I feel like stiffer feels more communicative and responsive. I’m not talking super stiff, but definitely stiff enough a normal person wouldn’t drive it daily.
I have a 2003 Miata running Feal 441 coilovers with 600/500 springs and front/rear sway bars on 225/45/15 RS4s. I love it….feels just right…not terribly stiff, but certainly not soft.
Old 04-29-2022, 04:06 AM   #11
strat61caster
strat61caster's Avatar
The way the suspensions are designed on a Miata vs 86 those 600/500 springs on your Miata are effectively softer then a 500/500 setup on an 86.
https://www.ft86club.com/forums/showthread.php?t=9936
Then you account for having a chassis that is actually stiff and well here we are.
Generally 86s without aero don’t go past 500/500, sometimes up to 600, but past that and you’re trying to get aero and slicks to work. Sounds like you would be plenty happy in the 400-500 range.
Stiffer rear springs makes sense for multiple reasons, but most off the shelf kits on a budget have either an internal compromise or assume you aren’t actually chasing perfect handling. Get a decent damper with range and don’t be afraid to change springs imho.
imho the chassis is far more sensitive to alignment then spring rate changes so a lot of “different” things can work. And most companies don’t publish their bump stop rates so don’t judge a coil over solely on the springs, you’re really buying a damper, springs sand bump stops are cheap and easy to change.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
Captain Snooze (04-29-2022), CSG Mike (04-29-2022), Evil Rocky (04-29-2022), Racecomp Engineering (04-29-2022)
Old 04-29-2022, 04:34 PM   #12
Kulebrero1
Drives: Gr86
Great info.
What are some popular setups? 400/400?
Old 04-29-2022, 08:59 PM   #13
strat61caster
400/400 is pretty popular, starting rates on the RCE T2, I’ve driven as split as far as 300/500
ineedyourdiddly
JDM TRD Springs / Coilovers vs USA TRD Springs darksnyder Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-12-2019 09:11 PM
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs leunglambs NY / NJ / CT / PA 3 06-09-2017 02:49 PM
Springs VS Coilovers JARE_ee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 10-08-2014 08:47 PM
Springs over coilovers ? brocktwalker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 02-24-2013 11:13 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
