Old 04-23-2022, 05:38 AM   #1
DerJuso
Drives: Gt86 2013
Gt86 starts and stalls after 3-4 sec
Hello! I have some Problems with my GT86.
when i start the car it starts running (not very smooth) at like 1200RPM (think thats normal to coldstart) but then its starts to go down like to 900rpm and then it shuts off :/ recently i worked on the directinjection system because i had a P0171 AFR lean code. after i took my carly adapter i got some codes.
B1572
U0100
U0164
U0140
U0155
I dont have any plans. And really need help.
CAR: 2013 GT86 AT
DerJuso is offline   Reply With Quote
Old 04-23-2022, 06:22 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Injector ECU not tight.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
alex87f (04-27-2022), Ultramaroon (04-23-2022)
Old 04-26-2022, 03:29 AM   #3
DerJuso
Drives: Gt86 2013
No the ECU is tight i made that mistake before
The Following User Says Thank You to DerJuso For This Useful Post:
x808drifter (04-26-2022)
Old 04-26-2022, 06:31 AM   #4
BlkTrax
Drives: Car
The B1572 code is telling you there is either a problem or no connection to verify the Immoblizer. Its going into anti theft shut down.
What ever you disconnected , make sure you didn’t damage any pins in the connector.
BlkTrax is offline   Reply With Quote
Old 04-26-2022, 11:11 AM   #5
DerJuso
Drives: Gt86 2013
I only took of the intakemanifold and the stuff around to check the Direct injectors. where should i start? But thanks alot for this peace of info!
Old 04-27-2022, 06:56 AM   #6
tig86
Drives: Subaru BRZ 2013
Error U0100 indicates a loss of communication with the engine control module/powertrain control module. As I don't know the solution it will be better if you find a professional for resolving the problem.
tig86 is offline   Reply With Quote
Stalls after start cold. solidsnake11 Software Tuning 0 05-16-2020 10:14 PM
BRZ down... Stalls right after start bravedeer Issues | Warranty | Recalls / TSB 12 09-12-2018 06:39 AM
HELP! BRZ 2017 stalls when switching to OL Muchikori Software Tuning 5 05-27-2018 11:16 AM
FR-S - AT nearly stalls when stopping WryGuy Issues | Warranty | Recalls / TSB 12 05-27-2016 03:04 PM
Car almost stalls but clutch is all the way in when stopped LaertesSon Engine, Exhaust, Transmission 11 05-13-2014 05:55 PM
