Old 04-15-2022, 08:35 PM   #1
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
AT Transmission Cooler solutions?
Does anyone know if there's still any AT cooler kits available for 2017+ BRZ? I ordered the Stark Performance Kit but it seems like it was discontinued and the seller cancelled the order.
TheBoss77 is offline   Reply With Quote
Old 04-16-2022, 04:28 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
Here you go:
https://www.sspperformance.com/brz-f...ler-a960e.html
Old 04-18-2022, 01:20 PM   #3
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
Thanks brother!
Does anyone on here run with it? Any opinions, things to watch out for?
Old 04-18-2022, 04:52 PM   #4
Espi
Espi's Avatar
Drives: 17 BRZ
Long story short I had one, never installed and sold mine. I've never had any overheating problems with the transmission. Also, there is a limp mode the car will go into if the transmission overheats for any reason. Allowing you to safely pull over or drive into a safe area.
I instead went with an HKS oilcooler for my motor. I was frequently seeing 270/290 on the mountains and now I haven't seen anything above 220 in over year.
Are you planning on tracking your car? If you are in need of a tranny cooler check out this thread where you can read some information on someone installing and running one.
https://www.ft86club.com/forums/showthread.php?t=69139
Also if it helps a buddy of mine running a turbo AT FRS regularly tracks his at Road Atlanta. He's had no need for one.
cheers!
Espi is offline   Reply With Quote
Old 04-19-2022, 10:31 AM   #5
TheBoss77
TheBoss77's Avatar
Drives: Toyota 86
cheers!
I have an oil cooler waiting to be installed, it will be done in the next few weeks.
This will be a dedicated track car that I'm going to build out over the next few years. Goal is to turbo it either next year or the year after that as I get more proficient in racing.
That build thread was awesome! Thank you, I don't feel so old any more getting into road racing
You have a good point about the transmission cooler, I should really see what the temperature hits during track day to see if I actually need one. I'll hold off on the purchase for now and see how things go during peak summer temperatures.
Old 04-19-2022, 02:21 PM   #6
Espi
Espi's Avatar
Drives: 17 BRZ
good luck with your build!
Automatic transmission cooler KDad2 Transmission and Driveline 2 01-24-2022 10:51 AM
SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge tws98 Engine, Exhaust, Bolt-Ons 0 05-28-2019 10:50 PM
FS: Torque Solutions Transmission mount insert & Shifter bushing skylinekin Transmission and Driveline 1 09-10-2018 08:30 PM
Automatic Transmission Cooler RYU Engine, Exhaust, Transmission 9 11-14-2013 02:15 PM
Transmission cooler? Tye300 Engine, Exhaust, Transmission 2 11-05-2013 02:55 AM
