Old 04-14-2022, 08:33 PM   #1
toughguy39
toughguy39's Avatar
Drives: WRB Turbo Brz
Brz doesn't like to idle
Hi guys,
Recently went in for maintenance, swear this is like the third post I've made in a month. What happens is after I drive off after I've given it time to warm up, when coming to a stop and putting the car to neutral the car dies. It doesn't happen every time maybe 40% of the time. There are some drives it doesn't even come close to stalling. The problem seems to happen when A: it's hot outside(90F) and/or B: I don't idle for like 10 minutes. Currently in the tuning process, I'm on the second tune from my tuner. I've emailed him and am waiting for a response. I also seem to be running a little lean (14.7-15.3 AFR) at idle. Fuel pressure being reported by the flex fuel kit is at 55PSI and I'm running 93 octane. Other than this problem she runs great.
Mod list(changed from since working):
Dw300c and id1050x injectors
Flex fuel kit
Boost controller
EVAP disconnected, hoses clamped
Spark plugs
Belt replacement
New intake filter
Cam plate replaced
2017 intake manifold
Any suggestions are greatly appreciated!
toughguy39 is offline   Reply With Quote
Old 04-15-2022, 05:05 AM   #2
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Do you have a custom tune? If so, I would have the tuner take a look at it. There are multiple things there in your list that change dynamics.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 04-15-2022, 06:51 AM   #3
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
FA20 is pretty notorious for poor idling.
But since you've reached out to your tuner, you're in the right direction.
Personally I found slightly improved idling after I swapped out my dying battery, ignition coils, and spark plugs and Chevron/Shell gas.
After some hard long use, it can still have a bit of a rougher idle still but better than before.
Old 04-15-2022, 06:51 AM   #4
tomm.brz
Drives: brz 2017 hksv2
Let me guess.
Ecutek racerom and US base tune, like it ends with the letter C...
Bug. I talked about it often, no one ever cared about it, so there is no fix for you unless you force your tuner to convert your tune with an EU base tune... thing that he will not do it also because he's not aware of, and your idle will always suck
Old 04-15-2022, 06:52 AM   #5
tomm.brz
not really. once it settles and only DI is used for idle, is pretty rock solid
Who has idle problems, has actually tune problem
Old 04-15-2022, 07:01 AM   #6
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
No, its notorious. You can google it yourself, but here's an example of just how common it was (large car publications were publishing articles about it).
https://www.motortrend.com/news/we-h...g%20conditions.
https://www.autoweek.com/news/a19712...ay-fault-lies/
https://www.autoblog.com/2012/10/05/...e-ecu-reflash/
https://www.cars.com/articles/2015-2...1420683185723/
1200 hits:
https://www.google.com/search?q=frs+...=2560&bih=1307
Old 04-15-2022, 07:14 AM   #7
tomm.brz
it s notorius but i ve retune 70 cars since 2018 and no one has idling problem.. it s fixab le, just that most people can t find the right solution
stock tunes and ots tunes Have idling problems btw. So do every custom tune that has idle set like them.
Old 04-15-2022, 07:58 AM   #8
makinen
makinen's Avatar
Drives: Toyota 86
Do flash new tune when the engine is warm. And search "subaru idle relearn".
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 04-15-2022, 08:21 AM   #9
tomm.brz
You probably have an Asian base tune as your custom tune, with no bugs
Those guys have US base tunes that have a bug with ecutek racerom that will force them to use PI during idle.. they ll never get a steady idle no matter how they help with the relearn, specially with big injextors
Old 04-15-2022, 08:33 AM   #10
OK so your first 3 links are from October 2012 so not sure how many people actually had an issue. They all are just clickbait's parroting each other anyway not even independent investigations. The issue was fixed before 99% of the cars wee ever sold.
Your 4th link is an issue very specific to one model year with AT only. Again it was fixed with a simple update.
Your 1200 other hits mostly start with "I have an XXX turbo or tune and have idle issues". Pretty much supports they are a mod and tune related problem. Oh and of course there are the many many "Happens when the A/C is on" which is perfectly normal but some people refuse to understand that.
Idle issues are not common on unmodded cars after the very first batch. If somebody with a tuned car has this issue they need to check the tune not ignore it and say "OH these engines all do that". They don't.
Old 04-15-2022, 01:57 PM   #11
Lantanafrs2
Drives: 2013 frs red
The only time my idle gets weird is when the ac is turned on/off
Old 04-15-2022, 02:07 PM   #12
Ultramaroon
not playing cards
Ultramaroon's Avatar
I have never had an idle issue with my bone stock '13. It still has the second ROM, the one where they removed the DI seal-blowing feature.
Old 04-15-2022, 03:05 PM   #13
spike021
spike021's Avatar
This pretty much, speaking from experience...
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 04-15-2022, 03:32 PM   #14
tomm.brz
while it is perfectly normal, there is still a way to tune this out and minimize it
Car doesn't crank :( Jaes86 Issues | Warranty | Recalls / TSB 5 12-04-2019 01:14 AM
Need HELP. Car doesn't turn on cocoy_labuyo Engine, Exhaust, Transmission 4 04-21-2018 09:18 AM
It doesn't work!! Photomikes garage FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 03-06-2017 01:23 AM
something doesn't look right with my rom kaluce Software Tuning 2 07-30-2016 10:07 PM
What color would you want the FRS/BRZ to have that it doesn't have? Wilsonk227 BRZ First-Gen (2012+) — General Topics 142 05-17-2013 08:26 PM
