Old 11-29-2019, 07:03 PM   #1
Jaes86
Drives: 2017 Toyota 86
Car doesn't crank :(
Put a new battery in today. Car turned on for a bit then when I put it in reverse, oem back up camera doesn't show on HU.
Now when I want to start it again, it doesn't crank. Clock flashes whenever I turn the key over.
Car is a 2017 Toyota 86 Automatic.
https://streamable.com/y2l4f
Jaes86 is offline   Reply With Quote
Old 11-29-2019, 08:02 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would check the battery again. loose connection?
Old 12-01-2019, 01:04 AM   #3
Jaes86
I've tightened everything down.
Old 12-01-2019, 01:28 AM   #4
humfrz
Maybe:
* you installed the battery backwards?
* the battery cable connectors or the posts are glazed or corroded?
* the big fuse on top of the battery is bad?
* maybe the new battery wasn't charged up when it came off the shelf?
humfrz
Old 12-02-2019, 08:59 PM   #5
Decep
Drives: 2013 FR-S Series 10
did you rule out a defective new battery?
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 12-04-2019, 01:14 AM   #6
highway7
Drives: FRS 2013
Sounds like issue with the new battery
highway7 is offline   Reply With Quote
Second time crank seal leak possible crank walk kiichiro Engine, Exhaust, Transmission 13 09-19-2018 05:57 AM
[GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt reeves Engine, Exhaust, Bolt-Ons 0 08-22-2018 07:01 PM
Car won't start - doesn't try to crank at all, but lights are working HELP cdo221 Issues | Warranty | Recalls / TSB 28 06-06-2018 06:30 PM
Need HELP. Car doesn't turn on cocoy_labuyo Engine, Exhaust, Transmission 4 04-21-2018 09:18 AM
something doesn't look right with my rom kaluce Software Tuning 2 07-30-2016 10:07 PM
