Old 04-13-2022, 02:11 PM   #1
parasox
Drives: 2020 Toyota 86 Gray
2020 Toyota 86 OEM Headlights question
I'm quite new to the ft86 community, purchased a 2020 Toyota 86 base a couple months back and I'm really enjoying it! I couldn't find a post related to the headlights and the few I found seemed like a different build so I figured I start a new post.
I have noticed the headlight beams seem to be "bouncy" as in I can visibly see the light beam moving up and down off of cars in front of me and in the dark surrounding areas/ distance street signs. I'm thinking I may not be use to the led cut-off being so clean cut as my last car was a Scion tc, though I have noticed the beam cut off in other cars so it could just be that led lights are getting brighter. I do live in the high desert of Socal so the roads tend to be a little more rough so that could be another factor. I have also noticed on darker roads people are flashing their brights at me when I have normal lights on.
My main question would be is this normal for the oem headlights and is there a way to access the light bulb is to check if its loose, I couldn't find an opening anywhere seems sealed shut compared to previous model years. The car has the auto headlight adjust setting from what I can tell with a few manual adjustments so I may try that. Appreciate any suggestions or comments.
parasox is offline   Reply With Quote
Old 04-13-2022, 09:13 PM   #2
FSFRS
Drives: '13 FR-S Firestorm
It will bounce up and down depending on how stiff your suspension is because the cut off is very precise like you said. It's a LED headlight so there isn't going to be anything loose.
You can manually adjust them down with a 8mm if you want.
FSFRS is offline   Reply With Quote
headlights
FS: 2020 Toyota 86 OEM Headlights lost4ever264 Exterior Parts (Aero, Lighting, Etc.) 10 04-16-2022 01:15 PM
2020 BRZ tS Fluid Question Alistia Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 07-15-2020 09:13 PM
2020 Subaru BRZ Audio Question Alistia Electronics | Audio | NAV | Infotainment 12 05-12-2020 08:33 PM
2020 Toyota 86 Hakone Edition at Torrance Toyota MJones_RB Southern California 3 02-08-2020 01:29 PM
2020 Toyota 86??? Twin-Dragons Scion FR-S / Toyota 86 GT86 General Forum 225 01-02-2019 01:33 PM
