Old 04-06-2022, 09:54 PM   #1
Spairo
Drives: 2013 FR-S 6 spd in Halo
CAS-CAM Plate Use
For those that have installed a CAS-CAM plate and track their cars, do you use the plate to make adjustments on your own as you dial in the car or do you only have a suspension shop make the adjustments?
Sent from my SM-G950U using Tapatalk
Spairo is offline   Reply With Quote
Old 04-07-2022, 01:24 AM   #2
whataboutbob
AutoX-10/10ths every run
Only adjusted them as part of a full front end alignment.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Spairo (04-07-2022)
Old 04-07-2022, 07:51 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
I've done both. Generally I set it to minimum caster and maximum camber and let the shop just do toe settings.
Spairo (04-07-2022)
Old 04-16-2022, 10:43 PM   #4
Danny318
Drives: 2019 BRZ
I adjust them but you have to adjust the toe anytime you change the camber. I do it with toe plates and tape measures.
Danny318 is offline   Reply With Quote
The Following User Says Thank You to Danny318 For This Useful Post:
marco_mc22 (04-17-2022)
Old 04-17-2022, 10:36 AM   #5
strat61caster
strat61caster's Avatar
I’ve adjusted myself, yes toe changes, do some measurements and see how big of an impact it is, toe plates can get you back to where you want for cheap.
ineedyourdiddly
Old 04-17-2022, 12:37 PM   #6
Spairo
Thanks Danny and Strat. That is good to know. I had not considered the impact on toe. Obviously, this is my first foray into setting up a suspension for track use. I won't be going too far afield anytime soon, but the 'on the fly' adjustability of camber plates had me curious.
The Following User Says Thank You to Spairo For This Useful Post:
strat61caster (04-18-2022)
OEM BRZ License Plate Frame & iJDMtoy License plate holder AW0802 Exterior Parts (Aero, Lighting, Etc.) 1 05-11-2019 12:39 AM
*GROUP BUY* Rho-Plate License Plate Mounting Kit $40! Massdrop Groupbuys 45 10-15-2013 07:07 PM
License plate covering front plate effect cooling? Wolfkiller Scion FR-S / Toyota 86 GT86 General Forum 4 05-04-2013 07:19 PM
[For Sale] Rho-plate Tow Hook Mounted License Plate rack pizzahead20 Canada Classifieds 0 08-23-2012 12:06 AM
Do you live in a one plate or two plate state? SCIONIZED Scion FR-S / Toyota 86 GT86 General Forum 36 05-04-2011 04:13 AM
