Old 04-05-2022, 03:59 PM   #1
suppjc
Drives: 2015 Scion FR-S Firestorm
TPMS battery replacement?
Hey guys,
I'm about to switch my original primacy hp to something else as the tires are worn and aged (second owner, they should be original tires). Something like Bridgestone Potenza Sports is being considered now.
While changing my tires, I was wondering if I can replace the battery for the tpms sensors. I've looked up the forum but cannot find anything mentioning the battery. It's 2015 model, so I thought I might as well replace the battery too. I was hoping to bring the battery to the tire shop myself and try to avoid extra fee for replacing tpms battery by themselves (if it's a thing).
Thanks!
suppjc is offline   Reply With Quote
Old 04-05-2022, 04:39 PM   #2
markitect
Drives: Scion FRS
Most tire shops will charge you for a TPMS kit, which includes new O-ring, and battery. I had mine done recently so I can see if they put a PN on my invoice.
markitect is offline   Reply With Quote
Old 04-05-2022, 06:15 PM   #3
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
No. The OEM TMPS are completely sealed.
If it runs out of battery, you need to buy a whole new TPMS unit. Maybe some aftermarket TPMS have replaceable batteries, but it's unlikely
EndlessAzure is offline   Reply With Quote
Old 04-06-2022, 06:41 AM   #4
saltywetman
Drives: 2020 Toyota 86 GT 6M
I never knew tpms batteries are replaceable either. I thought they were sealed and sensors have to be replace once the juice runs out.
Looking at youtube how to videos on replacing the batteries they all seem to be home hack jobs rather than something a shop would do. Would probably get charged more for labor to replace those batteries than replacing the entire sensor depending on how much they charge you for the battery. You would def need more than just a battery and o ring as you have to scrape out all that filler stuff and reapply if after your manage to swap out the battery
saltywetman is offline   Reply With Quote
Old 04-06-2022, 11:21 AM   #5
suppjc
I was looking at tires at Costco and they said they will charge a few bucks extra for tpms. Wasn't too sure if they do it correctly or just another way for them to rip off a few bucks tbh.
Thanks!
Old 04-06-2022, 11:22 AM   #6
suppjc
That's probably why I couldn't find any post about changing the battery or general care and stuff? I might just need to stick to the original one until they die.
Thank you.
Old 04-06-2022, 11:23 AM   #7
suppjc
TBH I'm ignorant in tpms and just assumed I would need to change the battery at one point. Didn't know anything about the seals either. Might just hang on to the current one until they die.
Thank you!
Old 04-06-2022, 10:37 PM   #8
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
You are probably good for at least another 3-5 years on your current set. Wait till your next tire purchase.
2020BRZtS is offline   Reply With Quote
Battery replacement oem Silverz Scion FR-S / Toyota 86 GT86 General Forum 28 03-31-2023 11:36 AM
Battery Leaking - 4th Replacement djrbash Issues | Warranty | Recalls / TSB 23 02-14-2021 11:16 PM
Replacement Battery jasonojordan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 01-24-2017 06:15 PM
Car Audio Battery Replacement brzstormtrooper Electronics | Audio | NAV | Infotainment 0 03-23-2016 07:38 AM
Replacement Battery slizoth Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-09-2014 02:04 PM
