Second lambda extender
Can you please suggest me where to buy, or find the plugs to make it?
Thank you |
Drives: brz 2017 hksv2
secondary O2 spacer doesn't work good on this platform
It will mess with the A/F#3 correction, unless you disable it, so your cruising and transient afr will be a mess It will trigger a CEL after a while, even if you disable the A/F#3 corrections, can t remember the code but it is the DTC that relates to "sensor 2 bank1 too lean".. again, unless you disable the DTC (and if ecutek found the DTC in first place) It MAYBE corrects the P0420 cat DTC, which requires anyway a single click on the tune to be deactivated and doesn't influence anything else When you disable A/f#3 and all DTCs you can even delete the O2 sensor, so the spacer is useless at this point Can't help you to find a good O2 spacer, but if you use it, use it temporary because it messes things |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Compelica (03-21-2022) |
Sorry, I hadn't been clear. I don't mean a spacer to prevent CEL, I meant a wire extender...
AutoX-10/10ths every run
This is the company I used to have an extension made: https://iwireusa.com/
| The Following User Says Thank You to whataboutbob For This Useful Post: | gpvecchi (03-21-2022) |
| OFT V1 + OBD Extender cable with on/off switch | paintdude258 | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-12-2019 12:40 AM |
| Emission Inspection OBD2 Lambda | stefodrom | Software Tuning | 10 | 04-05-2018 02:44 AM |
| O2 Lambda Sensor Deactivation? | stefodrom | Software Tuning | 9 | 09-30-2017 11:10 AM |
| GS:Gold we are likewise shifter extender. | jay92 | Interior Parts (Incl. Lighting) | 8 | 09-27-2016 01:37 AM |
| O2 Sensor Extender & Spacer | Donbrz | Engine, Exhaust, Transmission | 1 | 08-03-2015 11:46 PM |
