Old 03-20-2022, 08:41 PM   #1
TkMash
Drives: 2013 scion fr-s
Fr-s rear end
i am finally getting my ls into the car which will be a lot of fun but i am concerned about the rear end of the car. With stock tires and wheels i should be okay but i would like to add some bigger wider tires in the future. i am planning on doing a ford 8.8 swap but i am concerned how much power the unibody can handle. if anyone knows the limits of the fr-s body it would be muchly appreciated.
TkMash is offline   Reply With Quote
Old 03-22-2022, 11:01 AM   #2
Axis2011KR
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
You aren't going to have any issues with the body. There are plenty of people running 265's all the way up 335's with over 800whp on swap setups without issue.
Axis2011KR is offline   Reply With Quote
Old 03-22-2022, 02:34 PM   #3
Ebush
Drives: 2017 Hot Lava 86
If your planning to make enough power that you feel concerned about the chassis being able to take it, I’d imagine you would be adding a cage. That would strengthen the chassis quite a bit.
Ebush is offline   Reply With Quote
Old 03-22-2022, 11:14 PM   #4
Icecreamtruk
Drives: Track preped NA FRS
275s semi slicks with significant aero here, at around 380whp (na ls1 setup for road race and time trials). I dont launch the car, it only uses 1st and 2nd to iddle/limp around the paddock so maybe im not the toughest on the equipment but so far its all good. I do have a full cage, that probably helps with chassis strenght.
Old 03-23-2022, 12:13 PM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Why even swap at all?
The stock diff takes supra parts.
WTF kind of power are you thinking of?
FS: Racer X Rear LCA, Hotchkiss Front Bar, Raceseng 1" Rear Drop Mounts Kuro86 Brakes, Suspension, Chassis 4 07-26-2017 03:01 AM
WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights Apples_ZN6 Canada Classifieds 0 06-04-2017 11:27 AM
USDM - Rear foglight indicator in cluster? Trying to do a quality rear fog light inst nalc Cosmetic Modification (Interior/Exterior/Lighting) 8 12-10-2015 04:48 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
WTB: REAR window top Brake Light (just top half with leds) or full rear deck Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 1 08-31-2013 02:23 PM
