Old 03-13-2022, 04:40 AM   #1
mosterjet72
Drives: gt86 turbo
ZA1JA01I for setting up a turbo using the Hybrid Speed ​​​​Density system
Hi all ! I installed a turbine on a GT86 and for several years I have not been able to set up an ECU from ZA1JA01I. I want to ask you for help in obtaining and determining the ROM disk ZA1JA01I for setting up a turbo using the Hybrid Speed ​​​​Density system
mosterjet72 is offline   Reply With Quote
Old 03-13-2022, 05:31 AM   #2
tomm.brz
Drives: brz 2017 hksv2
Do you have oft then? or tactrix? ican remember if there are available patched A01I with SD tunes around but you should definitely go with ecutek for a SD turbo tune
Old 03-13-2022, 01:02 PM   #3
mosterjet72
Drives: gt86 turbo
This is the only turbo gt86 in my area. I set it up for stock rom but I'm not satisfied with the result. The engine is reinforced with pistons, connecting rods and liners, a fuel pump. no access to ecutek. I hope to find definitions and roms more budget than ecutek. I myself am familiar with tuning the ecu motec linkecu CarBerry 16bit Speed ​​Density Project. I have my own dynomax machine.
The Following User Says Thank You to mosterjet72 For This Useful Post:
Danny318 (04-22-2022)
Old 03-13-2022, 09:08 PM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Old 03-14-2022, 05:08 PM   #5
elBarto
elBarto's Avatar
Drives: Toyota GT86
Back in the day, ztan made a tune for his A01G car with Speed Density, flex fuel and was running a turbo. I know Wayno made a port for his A01I car, but as far as I know he only ported the flex-fuel part, not the Speed Density. But you can always contact him,
http://site.wayneroms.com:8000/
But if you want a good tune, you're going to need ECUtek
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 03-18-2022, 06:56 AM   #6
steve99
Only the manual A01G rom was patced by ztan for speed density
if your car is auto A01I then there is no speed density patch available for opensource tuning .
You can tune for boost without SD but on a standard diameter maf tube your limited to about 10psi or so before maf maxes out.
Then you have two options, use a maf sensor from a wrx\forester turbo car its plig and play will give you about 30% more maf reading ( will need recalibrating)
or go to a bigfer maf tube diameter and rescale stock maf sensor for that
otherwise if you must have SD your going to need to use ecutek system instead but more expensive
Old 04-19-2022, 09:08 AM   #7
Ruuuust
Drives: Japan
wow i want this set too
time tracking software recommended site
Ruuuust is offline   Reply With Quote
Old 04-19-2022, 03:31 PM   #8
x808drifter
LMGTFY
reported
Angle sensor not functioning​ Schace Cosmetic Modification (Interior/Exterior/Lighting) 16 02-28-2025 04:17 PM
Taillights​ with hard water spots inside Jajanken86 Cosmetic Modification (Interior/Exterior/Lighting) 9 03-31-2017 01:35 AM
The All New ATI FR-S/BRZ​/FT86 "Triple Meter" G​auge Pod ATIPods Interior Parts (Incl. Lighting) 7 09-18-2014 03:14 PM
The All New ATI FR-S/BRZ​/FT86 "Triple Meter" G​auge Pod ATIPods Cosmetic Modification (Interior/Exterior/Lighting) 16 09-18-2014 03:10 PM
