Old 03-12-2022, 08:39 PM   #1
Enrique_13
Drives: 2013 Subaru BRZ
2013 BRZ Headlight Replacement
Hello I need some help finding Headlights for a 2013 BRZ. I have D4S bulbs and I’m having trouble finding some online that fit with these bulbs. Most that I’ve seen require D2H bulbs. Any help would be appreciated!
Enrique_13 is offline   Reply With Quote
Old 03-12-2022, 10:26 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
D4S is a very common xenon bulb size. Most auto parts stores stock them, and if they're out, thousands of online retailers stock them, and if you need it faster, the dealers stock them
Are you looking for something more specific than an OEM replacement?
I guess I'm just confused-- are you replacing the bulbs, or the housings? Needs more specifics
Old 03-13-2022, 03:31 PM   #3
Enrique_13
I’m looking at VLand headlights but apparently they require D2H bulbs so I’m looking for headlights that can work with D4S Bulbs.
Old 03-13-2022, 05:13 PM   #4
soundman98
soundman98's Avatar
i don't think you'll find anything. there's nothing that says that an aftermarket headlamp can't go to a different bulb than originally installed, so many change to a different/cheaper bulb instead to cut down on costs.
Old 03-14-2022, 10:42 PM   #5
Enrique_13
So these were another ones I was looking at, but the bulbs are different. I have Ballasts that support D4S D4R. So these headlights won’t work for me.
https://shop.redline360.com/products...SABEgJCm_D_BwE
Old 03-15-2022, 04:08 AM   #6
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
If you're looking for bulbs, you'll never go wrong with one of the best HID/LED makers out there, Diode Dynamics: https://www.diodedynamics.com/replac...-brz-pair.html
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 03-15-2022, 10:46 PM   #7
Skyfighter
Drives: 2015 Subaru BRZ
Hey guys this is a little different topic. I have a 2015 subaru brz limited and since I purchased the car the fog lights have not worked. I've checked all the fuzes and the bulbs are brand new. I looked for a relay but I don't see one for fog lights. I don't know if I'm just looking all around it or not. But if anybody knows where the fog light relay is and possibly with picture that would be great.
Skyfighter is offline   Reply With Quote
SOLVED - headlight bulb replacement RickyRacer Issues | Warranty | Recalls / TSB 9 05-08-2016 11:12 PM
replacement headlight unit not focused Stratoside Issues | Warranty | Recalls / TSB 6 01-15-2016 03:24 PM
Headlight bulb replacement Alupinski Cosmetic Modification (Interior/Exterior/Lighting) 2 03-30-2015 04:02 PM
Question on series blue headlight replacement ScionOfHorus BRZ First-Gen (2012+) — General Topics 6 11-12-2014 09:11 PM
Adding Fog Lights + Headlight Stalk Replacement Void Warranty? JohnAyySays Issues | Warranty | Recalls / TSB 1 05-08-2013 09:07 PM
