Old 03-06-2022, 09:21 PM   #1
DrMusky29
Drives: 2013 Subaru BRZ
2015 BRZ engine valve tick?
Long story short, my 2013 BRZ's engine had rod knock after 146k miles, so in the essence of time and money, I swapped in a used 2015 w/ 80k miles. It runs just fine but... it has what sounds like valve tick but I'm not quite sure.
At 0:05 is when the tick is real prominent, and 0:10 there's a pretty bizarre sound that comes out too that I have no idea what it could be.
Any thoughts?
Thanks in advance.
DrMusky29 is offline   Reply With Quote
Old 03-06-2022, 11:47 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
the sound at 0:10, did you hear that in person, or only on camera? almost sounds more like a camera/mount noise than a car noise
Old 03-07-2022, 11:22 AM   #3
DrMusky29
That sound at 0:10 was also heard in person when I didn’t have my camera on.
Old 03-07-2022, 12:13 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Is your ac compressor on? Your hose looks collapsed.
Old 03-07-2022, 02:00 PM   #5
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
High Pressure Fuel Pump. Mine makes weird sounds too.
BigTuna is offline   Reply With Quote
Old 03-08-2022, 04:10 PM   #6
radroach
Drives: car
Take a long screwdriver and put it to the valve covers, and the handle to your ear to listen for vibration. I barely hear any noise from the valvetrain, its very quiet in there. Use this method to listen around the different parts of the engine, like the fuel pump and injectors, and the transmission.
Another source of noise might be the clutch throw out bearing. A few years ago I was also investigating a weird tapping sound on revs, and it turned out that it was clutch bearing rattle. I'm on my 3rd bearing now!
Old 03-08-2022, 04:21 PM   #7
radroach
Drives: car
@DrMusky29 here's a video I took when I noticed rattle. Fixed it later by putting in a new TOB.
(there is an audio sync issue in the video)
Old 03-24-2022, 06:17 PM   #8
DrMusky29
Well we ruled out an exhaust leak at the heads of the manifold, though there was a substantial leak there, it was not the source of the sounds I’m hearing. I was thinking fuel pump as well, but I always figured the fuel pump made the chirping sounds and not necessarily whatever the hell this is. I’ll try the screwdriver trick and see what happens.
Old 03-24-2022, 07:12 PM   #9
Grady
Grady's Avatar
That sound at 10 is weird, does not sound engine mechanical. I would disconnect the cabin sound generator for a test.
Valve tick? Takumidesh Engine, Exhaust, Transmission 8 10-13-2017 02:35 AM
Engine tick? Jarrid'sBRZ Issues | Warranty | Recalls / TSB 4 06-06-2017 09:16 PM
Engine tick Riftur Engine, Exhaust, Transmission 14 02-05-2016 10:07 PM
Valve tick? mtblackfrs Scion FR-S / Toyota 86 GT86 General Forum 37 02-12-2015 03:08 AM
LOUD TICK-TICK-TICK sound on right hand side PoRco Issues | Warranty | Recalls / TSB 16 07-28-2014 12:55 PM
