Old 03-04-2022, 12:24 PM   #1
bevestrown
Been Chasing this Clunk for a Year
I call it the parallel parking clunk. Only hear it at very low/no speed when the wheels are turned all the way. Tough to tell if its coming from a specific side/both/the center
Replaced the struts and mounts with Bilstein B6s (which fixed some other issues)
Adjustable whiteline endlinks
Lubed the sway bar bushings
Any ideas? Steering rack?
bevestrown is offline   Reply With Quote
Old 03-04-2022, 01:08 PM   #2
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Sounds like it's hitting the fender liner to me, like plastic slapping back against something. Check that you aren't missing any pop clips. Does it make that sound on jack stands?
2020BRZtS is offline   Reply With Quote
Old 03-04-2022, 02:11 PM   #3
bevestrown
Once the load is remove the popping stops. There are some scrapes on the firewall behind the strut/end link but for the life of me couldn't figure out what might be rubbing. Old end links didn't have any rubbing damage to them either
Old 03-04-2022, 02:57 PM   #4
p1l0t
p1l0t's Avatar
Maybe try jacking the car up, putting jack stands underneath it, and having a friend turn the wheels while you listen from underneath?
norcalpb (03-04-2022)
Old 03-06-2022, 02:02 AM   #5
norcalpb
norcalpb's Avatar
How many miles on the car and are you on your original front tie rods?
Old 03-06-2022, 03:25 AM   #6
Tokay444
Strut bearing or ball joint. Get your stethoscope out.
The Following 3 Users Say Thank You to Tokay444 For This Useful Post:
gen3v8 (03-06-2022), p1l0t (03-06-2022), Wally86 (03-10-2022)
Old 03-06-2022, 03:47 AM   #7
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Long shaft screwdriver poked into a suspect part with your ear against the handle. Makes a good stethoscope
gen3v8 is offline   Reply With Quote
The Following 4 Users Say Thank You to gen3v8 For This Useful Post:
Jdmjunkie (03-06-2022), nathand (03-08-2022), p1l0t (03-06-2022), Wally86 (03-10-2022)
Old 03-09-2022, 09:36 AM   #8
Kado
Drives: 2022 BRZ
"Quiet sonny, my screwdriver is talking to me again. It says... Be sure to drink your Ovaltine."
Kado is offline   Reply With Quote
The Following 2 Users Say Thank You to Kado For This Useful Post:
p1l0t (03-09-2022), Wally86 (03-10-2022)
FRS chasing BRZ at the Firm. Submarinesonce Tracking / Autocross / HPDE / Drifting 9 05-10-2018 11:02 AM
Rattle chasing.. fuddbutter Electronics | Audio | NAV | Infotainment 4 09-17-2017 09:17 PM
Chasing the White Rabbit BrianFRS Member's Car Journals 8 06-04-2015 12:27 PM
Chasing a Cayman S on Track Snozzberries FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 14 10-01-2013 08:34 PM
Chasing the concept look Shinjuku05 AUSTRALIA 24 08-17-2012 08:10 AM
