Old 02-26-2022, 06:28 PM   #1
multyvers87
multyvers87's Avatar
Drives: 2015 subaru brz
QUESTION ABOUT A 2015 BRZ
Hi there! Im new here, as this will be my first post!So I just managed to get my hands on oem suspension with under 2 k miles for 100 bucks, but theyre from a 2020 brz, I have a 2015. My question is, is it possible to put 2020 suspension on a 2015? Or are there issues?
Sent from my SM-G986U using Tapatalk
multyvers87 is offline   Reply With Quote
Old 02-26-2022, 06:42 PM   #2
Ashikabi
Ashikabi's Avatar
If they physically bolt up then should be fine. Be a pioneer. Try it and let us know for the next guy who asks
Old 02-26-2022, 06:46 PM   #3
multyvers87
Oh boy...i was hoping i wasnt the first i might be as slow as my car, but what do you mean if they bolt up? Sorry if im coming like dummy dumb
Old 02-26-2022, 07:00 PM   #4
Brz-123
They work just fine. Why do you want to replace your 2015 suspension though? There is no perceivable gain , just Toyota saying they changed damper rates..
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 02-26-2022, 07:21 PM   #5
Ashikabi
Ashikabi's Avatar
If they are a close enough size/shape that you can get bolts into them. For a pretty extreme example: if the tophat has 2 bolts instead of 3, it's not gonna fit. Or if the length is different. I dunno if youre first but you're the first I've seen ask. Worst case scenario your have to put your old ones back on
Old 02-26-2022, 07:41 PM   #6
multyvers87
Its more that one of my coil over is clunking and popping when turning, so i figured it may be worn and older as they came with the car, so i thought id go back to stock oem suspension in the meantime, and try it out as i never had oem suspension, and i got a bomb deal on 2020 suspension , so i thought, why the heck not, but i just want to make sure they fit and work on a model 5 years older, but it sounds like they do!
Old 02-26-2022, 07:42 PM   #7
multyvers87
Ahhhhh makes more sense! The front have 3 bolts and the back have 2, so that seems pretty normal! It seems that it may work, so why not try it!
Old 02-26-2022, 07:43 PM   #8
Ashikabi
Ashikabi's Avatar
Let us know how it goes
Old 02-27-2022, 01:40 AM   #9
Brz-123
I've done this (replaced with 2018 GT86 suspension) on my 2015 brz and it all fits perfectly.
Old 02-27-2022, 02:26 AM   #10
Ultramaroon
not playing cards
Ultramaroon's Avatar
Check https://parts.subaru.com or https://parts.toyota.com. Compare the part numbers for the suspension bits. That'll give you a better idea for compatibility.
Old 02-27-2022, 02:13 PM   #11
p1l0t
p1l0t's Avatar
Possible is a relative thing... my 2005 Subaru Impreza wagon has Forester brackets, Outback Sport springs, aftermarket trailing endlinks, AGM (STi basically) adjustable dampening struts... Gives it a mild lift I didn't include the spacers I had so it's only like an inch instead of 2 like my 03 WRX had. Mostly it was all bolt on.. Just remember that of you mess with any of the geometry you mess with ALL the geometry. (most everything is adjustable though). I assume* (not sure) it will mostly be bolt on which is what I think you are asking but I've seen VW beetle monster trucks possible is a very relative thing.
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
bcj (02-27-2022), Ultramaroon (02-27-2022)
Old 02-28-2022, 03:27 AM   #12
Brz-123
I think you are complicating it way too much. The OPs question is very simple, is a 2020 BRZ suspension backward compatible with a 2015 MY and the answer is Yes it is 100% compatible.
Old 02-28-2022, 03:27 AM   #13
Brz-123
There is nothing pioneering in this. It has been done many many times but for different reasons.
Old 02-28-2022, 03:33 AM   #14
Brz-123
@multyvers7 I'll try to help again. Yes 2020 suspension is fully backward compatible with a 2015 MY. I've been there done that...
The only difference is the spring rates between 2015 and 2020 with the latter being more Road biased.
Some pics of part numbers Name:  20191216_111436.jpg
Size:  86.7 KBName:  20191216_111424.jpg
Size:  91.7 KBName:  20191216_110919.jpg
Size:  79.6 KBName:  20191216_123805.jpg
The Following User Says Thank You to Brz-123 For This Useful Post:
p1l0t (02-28-2022)
Question about 2012 vs 2015 86s ephemerality Scion FR-S / Toyota 86 GT86 General Forum 12 03-02-2019 02:59 AM
FRS 2015 A/T question need someone who had the car for a longer time to help me out? elyugi1 Engine, Exhaust, Transmission 5 10-23-2015 10:57 PM
2015 FRS Stock Axel Back Price Question? Mr.Impreza CANADA 7 10-10-2014 07:33 PM
2015 FRS/BRZ Exhaust tip question babykwiss Cosmetic Modification (Interior/Exterior/Lighting) 13 09-12-2014 11:51 AM
2015 FRS/BRZ Exhaust tip question babykwiss Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 09-06-2014 09:36 AM
