Old 02-26-2022, 04:23 PM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Bad primary cat?
I have a a couple of signs that the primary cat has gone bad. I just want to confirm my suspicions before I knock it out. There's loss of power that's getting worse the last few times I the car took the car out. The upstream pipe temperature is higher than downstream. I was holding 2500rpm when the picture of the scan tool was taken. Last year, when I had the rocker problem, I had to drive the car 20-30 miles with a misfire which, I know, is death for a cat . It's an afe catted header .
All in favor of knocking the cat out say "aye"
Old 02-26-2022, 04:33 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I would say cat needs to go. If you can get the car on jack stands and check it with a cheap temp gun. Should be pretty obvious that way.
Old 02-26-2022, 08:00 PM   #3
blsfrs
blsfrs's Avatar
Thanks. Did that. Near as we could tell, looked like 200*c difference pre vs post cat.
Old 02-26-2022, 08:11 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Some quick googling shows the outlet should be a touch hotter then the inlet at the cat, which I didn't know. So for sure sounds plugged.
Old 02-26-2022, 08:59 PM   #5
blsfrs
blsfrs's Avatar
I found a couple of videos on back pressure testing. Just for giggles, I try it as further confirmation.
Old 02-27-2022, 09:22 AM   #6
Grady
Grady's Avatar
Time for a gut job!
Old 02-27-2022, 08:56 PM   #7
blsfrs
blsfrs's Avatar
Good increase in power. Still wants to bog down at higher rpms. Seemed to improve after a few wot pulls. I'm guessing the ecu will need a couple of drive cycles to figure itself out.
Jabbing the throttle showed back pressure with my handy dandy DIY gauge.
The primary cat was toast. It had come loose from the inside of the housing. Still took 45 minutes to get it out.
Gutting primary cat? jordanrw260 Engine, Exhaust, Transmission 6 07-30-2018 10:24 PM
Car only starts when primary 02 is unplugged j0hnnybk01 Issues | Warranty | Recalls / TSB 22 08-28-2017 11:13 AM
WTB Primary o2 sensor Frs300 Want-To-Buy Requests 0 08-22-2015 03:45 PM
1.75 primary too big for fa20? dipsticktuning86 Engine, Exhaust, Transmission 2 10-31-2013 06:31 AM
