Old 02-23-2022, 12:31 PM   #1
rbail1
Drives: 2016 Scion Frs, 2008 Mercedes CLS
Diagnostic Question P000A and C1201
I have two codes that appear simultaneously. P000a (camshaft A slow to respond bank 1) and c1201 (engine control system malfunction). I found it odd that the second code related to engine management is stored in the ABS/VSC/TRAC module. It's my guess that one is causing the other. I have already moved the VVT solenoid to see if code would follow. It does not. Still cam A bank 1. Code setting criteria list a few different possibilities. Low oil pressure/possible blocked journal. Possible bad VVT phaser/sprocket. Possible bad camshaft position sensor. Possible bad electrical connection. Code sets within a few miles after clearing but is not instantaneous. My question is this. Is there a diagnostic process for a blocked journal or VVT sprocket? Or am I just going to have to fire off the parts cannon at it? Changing the sprocket is a shit ton of work to find out that its a blocked journal. I am going swap cam position sensors and see what happens. Any input is appreciated. I seem to find a few people with the issue but no solutions or they take it to the dealer and they can't seem to fix it either. Also considering swapping abs module to see if it's a possible bad module but I hate coding VINs with my limited equipment. It's hit or miss. How are the pirate copies of Techstream that can be purchased online?
rbail1 is offline   Reply With Quote
C1201 and C1231 Codes Jreyes96 Issues | Warranty | Recalls / TSB 1 08-27-2021 10:43 AM
DTC C1201 HELP Please ABS ECU newfienorthca Issues | Warranty | Recalls / TSB 3 11-05-2020 02:43 AM
CEL/TC light code P000A iclouhd Issues | Warranty | Recalls / TSB 10 09-17-2020 08:36 PM
P000A and P0011 Riftur Issues | Warranty | Recalls / TSB 5 02-13-2017 09:32 PM
Code C1201 Dipstik-sportech Issues | Warranty | Recalls / TSB 2 06-26-2014 10:12 PM
