Old 02-23-2022, 11:39 AM   #1
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
Sticky Shifter
Just this week I noticed my shifter doesn't always center itself like it used to. If I push it to the left (between 1 and 2), sometimes it just sits there and doesn't return to center. Same thing when pushing it to the right (between 5 and 6). I read some suggestions on the forum and I plan on taking apart the shifter assembly this weekend to do a visual inspection. I plan on looking for rust at the rod linkage and checking for any lubrication issues. Any other advice on what to look for would be appreciated as this issue is affecting my shifts from 2-3 and downshifts from 5-4. I rely on the self-centering of the stick when performing these shifts, I have to pay extra attention now that it doesn't self-center.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 02-23-2022, 12:38 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
I've never felt this but the external links are pretty simple. If either of the links is sticky, the gear selector may not be clearing the shift gate. Does it re-center if you jiggle fore-aft?
I think you're on the right path with just getting underneath it to inspect.
Old 03-01-2022, 07:16 AM   #3
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Time to upgrade to MTEC Shift Spring Kit
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 03-01-2022, 08:33 AM   #4
Ohio Enthusiast
Drives: 2018 BRZ
Agreed - it really helped with 5->4 aggressive downshifts for me and improved 2->3 upshifts and helped moving between 3rd and 4th with confidence.
On the other hand, OP might be having an actual issue, if the shifter won't return to center in neutral... Or could the OEM springs be that weak?
Ohio Enthusiast is offline   Reply With Quote
Old 03-07-2022, 10:51 AM   #5
itsAlex
itsAlex's Avatar
I haven't had time yet to get underneath the shift boot, but just a few days ago it was a bit warm outside (10C) and I noticed the issue wasn't as pronounced that day. The temperature has dropped since (1C today) and it's more apparent again. I wonder what the correlation suggests.
Old 03-07-2022, 12:44 PM   #6
Ultramaroon
not playing cards
Spring is coming and it's time to get underneath it.
Sticky shifter on left side Sonicp9 Issues | Warranty | Recalls / TSB 16 07-27-2020 02:23 AM
Shifter action sticky? TOB? Am I imagining things? GrantedTaken Scion FR-S / Toyota 86 GT86 General Forum 15 08-23-2018 11:34 PM
Sticky Shifter Lust Issues | Warranty | Recalls / TSB 33 07-23-2017 01:21 PM
Sticky Shifter ansibe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 09-15-2016 12:59 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
