Old 08-23-2018, 09:59 AM   #1
GrantedTaken
Shifter action sticky? TOB? Am I imagining things?
Did not drive my car for a few weeks. Was away.
Drove it this week, and the shifter feels slightly off.
This is very very minor, but I think it's different.
Stiff. Like it doesn't center as precisely as it used to.
Or like it doesn't return as smoothly.
I have "jammed" a couple of shifts since it not sliding into the desired gear like a ninja psychic shifter, like it usually does.
Anyone ever feel this?
GrantedTaken is offline   Reply With Quote
Old 08-23-2018, 10:48 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Was the car fully warmed up? If not, see if it's smoother after driving it a few miles.
Or it may be time for a tranny/diff fluid change.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-23-2018, 11:02 AM   #3
radroach
Drives: car
My transmission has stuck in cold 1st-2nd gear shifts since it was new. Same behavior no matter what fluid change (though new fluid is a good thing maintenance-wise).
I think I had hard shifts into 2nd because of a transmission mount issue. Too much flex in the mount causing a clearance issue perhaps. Stiffening the transmission mount with a whiteline insert (next trying an STi mount) definitely reduced movement and clunking on low rpm shifts, making that much less of an issue.
As well, warming up the drivetrain is a daily routine for me to check shifting and braking, taking a drive around my apartment or on quieter roads before hitting busy streets. On colder days sometimes this warmup is absolutely necessary.
Matching speeds in this transmission is important for smoothness. Internally there are shafts that are slowed down between each upshift to match rpms.
As for your shifter alignment, Bushings become worn, or lose lubrication and can cause wear, misalignment. Or in my case, lost by my installer
Old 08-23-2018, 11:34 AM   #4
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
This sounds like a fun story! Do tell
mrderp is offline   Reply With Quote
Old 08-23-2018, 11:40 AM   #5
TOB will have zero impact on how stiff the shifter is.
Like said if the temperature has been cooler than you are used to there will be some resistance. You get used to it.
Old 08-23-2018, 11:40 AM   #6
radroach
Drives: car
@mrderp clutch throwout bearing by 50k miles for example (not my image)
@Tcoat it'll stick if the clutch drags
Old 08-23-2018, 11:42 AM   #7
To hell with that I want to know just how big his apartment is.
Swabodda (08-24-2018)
Old 08-23-2018, 11:43 AM   #8
radroach
Drives: car
@mrderp oh you mean my installer. Yeah after a clutch job the installer told me that it was normal for the shifter to have side-to-side play. I later found the rubber shift bushing in the trunk of the car.
Old 08-23-2018, 11:48 AM   #9
radroach
Drives: car
@Tcoat we have a smooth 25-mph road going around the block that's good for cruising around and warming up the car on. Everything else around is hills and fast turns so I like to get everything warmed, ready and checked before popping it through the gears while hurling down slicked banked roads.
Old 08-23-2018, 11:48 AM   #10
True but it is such a long shot I would not even consider it. I probably have the worst TOB failure on record here and it never caused a drag or shift issues. Well not until it completely blew and then I couldn't do a clutched shift at all. If his TOB is bad enough to cause shift issues he would have heard it screaming a while ago.
Old 08-23-2018, 11:53 AM   #11
@Tcoat we have a smooth 25-mph road going around the block that's good for cruising around and warming up the car on. Everything else around is hills so I like to get everything and checked before hurling it down a slick banked road.
Ah you meant apartment BUILDING. That is not what you said.
Old 08-23-2018, 01:33 PM   #12
humfrz
I suggest you not do anything till next week, then see if it still feels "off" -
humfrz
Old 08-23-2018, 07:27 PM   #13
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
As humfrz may be implying...
Hangovers can often make one's car seem to have problems which really don't exist.
ToySub1946 is offline   Reply With Quote
The Following 3 Users Say Thank You to ToySub1946 For This Useful Post:
atomicalex (08-23-2018), humfrz (08-23-2018), Swabodda (08-24-2018)
Old 08-23-2018, 08:25 PM   #14
So does reading forums!
Ultramaroon (08-23-2018)
Sticky Shifter Lust Issues | Warranty | Recalls / TSB 33 07-23-2017 01:21 PM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
Sticky Shifter ansibe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 09-15-2016 12:59 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
More 86 Twin drift action + Off road action knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 16 02-25-2012 07:55 PM
