Old 02-16-2022, 09:14 AM   #1
series420
Drives: '13 Toyobaru BRZ
In search of cooling options for an auto trans
Hello, my currents mods are as follows
• HKS High power catback
• JDL Custom over/mid pipe
• Ft86speed uneven length exhaust manifold
• Injen short ram intake
• Tein Flex A Coilovers with hydraulic bump stop
• StopTech Slotted rotors
• StopTech braided brake lines
• O.Z Ultraleggera 18x8.5 (18lbs/each)
• Bridgestone Potenza RE-71s
• OpenFlash tablet tune stage3(e85)
• Valenti Jewel tail lights
• Seibon Euro style duck tail spoiler
• Seibon FA Style carbon fiber hood
I am looking to upgrade the cooling systems of my car in preparation for supercharging. My car has an auto trans, so im not sure what my options are, while browsing online i havent not seen any labels to indicate whether they are made for MT or AT.
Any advice would be greatly appreciated, hope everyone is having a productive off season
2013 BRZ Premium
Injen short ram intake, OFT Stage2/e85
Ftspeed UEL headers, JDL front/overpipe, HKS high power dual outlet catback
series420 is offline   Reply With Quote
Old 02-16-2022, 09:34 AM   #2
Ashikabi
Ashikabi's Avatar
So you're looking for like a radiator? Or a transmission cooler?
If you need a transmission cooler I think you have to go with a pump driven unit like how drifters cool their diffs. Might have to add ports to the transmission case to add lines to the cooler. With an external electric pump.
As far as radiator, there are several options for upgraded stock fitment that don't matter what trans you have. If those don't look big enough, I've got a double pass radiator coming to the market soon. That will be the largest core on the market
Old 02-16-2022, 09:42 AM   #3
series420
Thank you for the quick response, I was initially planning on both radiator and oil cooler, however if there is that much work involved in the oil cooler with the AT, ill likely just do the radiator for now, and see how the temps are after installing the supercharger
2013 BRZ Premium
Old 02-16-2022, 09:54 AM   #4
Ashikabi
Ashikabi's Avatar
You say oil cooler... Oil cooler isn't hard to install. Transmission cooler is. I'm not sure that anyone has had real issues with transmission temps so I don't think you need to be concerned. Are you tracking the car?
Old 02-16-2022, 10:47 AM   #5
series420
I read your previous post wrong, my bad.
I will do oil cooler, and the koyorad is confirmed by manufacturer to work with AT.
My only remaining question now, is the ATF cooler in the radiator on our cars?
https://parts.subaru.com/a/Subaru_20...10-154-01.html this diagram has me wondering...
thanks again.
2013 BRZ Premium
Old 02-16-2022, 11:32 AM   #6
Ashikabi
Ashikabi's Avatar
thanks again.
I wasn't aware there was a transmission cooler. If there is, you could easily upgrade that to a bigger external unit
Old 02-16-2022, 11:36 AM   #7
series420
yeah on that diagram its part 31237
2013 BRZ Premium
Old 02-20-2022, 10:51 AM   #8
86TOYO2k17
Drives: 2017 toyota 86
A transmission ATF cooler is incredibly easy to install. No additional work to install than an oil cooler.
Most Auto trans owners who track the car and/or go boost install one.
Old 02-20-2022, 06:02 PM   #9
Flarpswitch
Flarpswitch's Avatar
Drives: 2022 BRZ Ltd, 2025 Ascent Touring
Keep in mind that the stock setup is also designed to ‘Warm up’ the transmission to keep it in that Goldilocks temperature range. I had installed a supplementary cooler on a car that at times I had to use the supplied cover to keep from losing too much heat. I had the same issue with engine oil coolers that had to be covered in the winter. Temperature gauges are a wonderful thing to have.
Flarpswitch is offline   Reply With Quote
Old 02-21-2022, 11:31 AM   #10
86TOYO2k17
The stock setup utilizes a coolant to ATF heat exchanger, no reason to bypass this, keep it in the loop, install a thermostatic fluid control valve after the HE before your ATF cooler to bypass the ATF cooler during warm up but always utilize the heat exchanger.
Should have a thermostatic fluid control valve for the oil cooler as well.
P0700 Auto trans Alfrz Engine, Exhaust, Transmission 1 06-19-2021 05:20 PM
Cooling options for FI 86’s, and tips/tricks for other good supporting mods AldoRaine Forced Induction 24 04-16-2020 08:14 PM
Does the auto trans learn? Impureclient Engine, Exhaust, Transmission 18 04-02-2020 10:59 AM
Engine Cooling options Magiclow Engine, Exhaust, Transmission 34 08-20-2018 05:19 PM
Auto Trans issue Triumphrider Issues | Warranty | Recalls / TSB 9 11-04-2014 07:34 PM
