Old 02-16-2022, 02:21 AM   #1
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
Exclamation Engine Re-tuning Help
Hello Everyone,
I'm facing an issue regarding the tune on my car as the car was already tuned by the previous owner before.
I recently rebuilt my engine, and now it stalls as soon as turned on. However, stays on with gas.
Engine was rebuilt from stock spec so below are the new specs:
Naturally Aspirated
Piston Size: 86.5
Compression: 10:0:1
Any advices what I should be doing next where should I look to get the car running?
Thank you,
H
I_amhassan is offline   Reply With Quote
Old 02-20-2022, 11:43 AM   #2
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Just a compression change shouldn't cause starting issues, it might be wise to double check the mechanicals/sensors.
Xero-Limit is offline   Reply With Quote
Old 02-24-2022, 05:50 PM   #3
I_amhassan
I_amhassan's Avatar
Drives: Toyota 86
Well, the harness is completely fucked and I’m looking to replace it since i keep getting random voltage codes for the knock sensor and camshaft sensor.. i changed one cam sensor and then it threw a knock sensor code
P0328
P0345
engine, rebuild, tune
Second gen engine tuning ayau Software Tuning 26 06-14-2023 10:04 PM
ECU and Engine Tuning Reference Guide swift996 Software Tuning 140 11-02-2022 12:18 AM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 03:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
How do you choose your engine managemet/ecu tuning? AMR Engine, Exhaust, Transmission 17 04-25-2013 01:16 PM
