Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-14-2022, 12:21 PM   #1
Powersfrs
Drives: Frs
Do last gen brake pads fit new gen?
Is there confirmation last gen brake pads fit new gen? Brakes on new gen are descent with good pedal feel. I get em pretty hot on canyon drives and so I need an upgrade.
Looking into hawks hp+.
Ridiculous!
Powersfrs is offline   Reply With Quote
Old 02-14-2022, 12:43 PM   #2
jvincent
jvincent's Avatar
Yes, they are the same size.
The Following User Says Thank You to jvincent For This Useful Post:
Powersfrs (02-14-2022)
Old 02-14-2022, 12:44 PM   #3
OkieSnuffBox
Drives: '23 BRZ Limited
Can you smell them? Is the pedal going soft like your boiling the fluid, or going hard like you've overheated the pads?
Old 02-14-2022, 02:38 PM   #4
Powersfrs
Drives: Frs
I can smell them
Pedal goes soft-ish.
Stopping gets longer.
I don’t go hard core on public roads yet the pads/fluids get hot and well they loose stopping distance/power.
Ridiculous!
Old 02-14-2022, 04:57 PM   #5
OkieSnuffBox
I can smell them
If you're getting the fluid that hot on the street, you should really take it to the track. And flush what you have in there with some quality stuff.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
timurrrr (02-15-2022)
Old 02-14-2022, 07:19 PM   #6
Powersfrs
Drives: Frs
I’m not boiling the fluid …the pads just can’t handle any descent heat. I’m also looking into more stopping power.
Ridiculous!
Old 02-14-2022, 09:55 PM   #7
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
I had this problem on my last car, upgraded to EBC yellows and was very happy with the results.
Midnightsky is offline   Reply With Quote
Old 02-14-2022, 10:52 PM   #8
Powersfrs
Drives: Frs
Was it a night and day difference in stopping power? How was the squeaking and dust? Those are actually my second option.
Ridiculous!
Old 02-14-2022, 11:56 PM   #9
Up4speed
Drives: 2023 BRZ Limited
You may want to try Ferodo 2500's. They are excellent pads for street/track. Work great, little to no squeal, and capable of track days. I've never tried them on a BRZ, but they work great on my GTI, and I track it all the time. I also recommend Motul RBF600/660 fluid.
Up4speed is offline   Reply With Quote
Old 02-15-2022, 12:53 AM   #10
Midnightsky
There are 2 options when it comes to dust and brake pads. You can either accept the dust that comes with a performance pad(yes some are a little better than others), or you accept the minimal stopping capabilities of a non performance pad. Unfortunately once you goto a performance pad, you will always be compromising on the extra brake dust. But, fear not, because the additional stopping power is 1000%(yes 1 thousand lol) worth it. There is lots of fantastic products out there today to help keep your wheels clean from the extra brake dust. Do not fear the brake dust, it's a mosquito bite compared to the angry polar bear mauling from brake fade and no runoff area.
The extra dust on the EBC's yellows was quite high compared to OEM. Unfortunately I don't have anything else to compare it to personally yet. The increase in stopping power was significant, no more brake fade was nice too lol.
Old 02-15-2022, 09:35 AM   #11
OkieSnuffBox
Yes, you are.
https://www.powerstop.com/brake-fade...ke-fluid-boil/
Old 02-15-2022, 10:27 AM   #12
Powersfrs
Drives: Frs
Thank you I’ll look into this setup!
Ridiculous!
Old 02-15-2022, 10:31 AM   #13
Powersfrs
Drives: Frs
Yeah I’m totally ok with dust and some squeal. I definitely want more stopping power with the added performance I got from my suspension setup. I had a type r previous to this car and those brembos were really good. I never had an issue and I did the same type of driving I currently do with the BRZ.
Thanks for your input
Ridiculous!
Old 02-15-2022, 11:54 AM   #14
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
I think it is a little confusing that people keep referencing 'stopping power'. Most OEM brakes are more than capable of providing enough stopping power to lock up wheels. So this means, generally, it is the tire that is the limitation in outright stopping power.
But we all know the stock brakes are designed to stop the vehicle hard once, maybe twice before being given a break to cool..
I see the advantage in better pads, higher boiling point fluids and even larger brake systems in maintaining stopping power under aggressive driving conditions, but not in increased 'stopping power'.
Even when you get into large monobloc multi piston calipers, my understanding is that they are not about applying more clamping force, they are about being able to use larger (and often times thicker) pads and still applying that force evenly across the pad surface. As well as the ability to user larger, thicker rotors with better heat tolerances, and often better venting systems for shedding that heat. Ultimately it is all about managing heat better.
I think this term is a bit misleading to the uneducated, and may lead to the belief they will get shorter stopping distances, which given the same tire, isn't likely to be true..
More 'stopping power' would require more capable tires to be utilized, otherwise it would just be wasted anyway. Aren't we really talking about maintaining stopping power, pedal feel and hopefully increasing the life of the pad/components in the process?
LRNAD90 is offline   Reply With Quote
The Following 4 Users Say Thank You to LRNAD90 For This Useful Post:
Dzmitry (02-15-2022), Midnightsky (02-15-2022), Tcoat (02-15-2022), Xed32 (02-16-2022)
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
FS: OEM wheels, HAWK HPS front and rear brake pads, OEM brake pads, TYC colins tails oppiee Canada Classifieds 4 10-07-2019 05:27 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
