Old 02-12-2022, 04:17 PM   #1
jaredshaw56
Drives: 2013 Scion FRS
Brake Light Issue
Hello, I have a 2013 FRS and everything runs well in the car but the only issue that has popped up are the brake lights. The tail lights are stock and this is a confusing problem for me to figure out.Basically, the turn signals/hazards and reverse lights work just fine and so do the headlights if that means anything. However, the brake lights themselves do not turn on at all or when the brake pedal is pressed. Checked the fuses those and those are just fine, any suggestions, explanations, or fixes to this problem? Anything would be greatly appreciated
jaredshaw56 is offline   Reply With Quote
Old 02-13-2022, 05:43 PM   #2
Kaotic Lazagna
Drives: GR Corolla
Check the connectors behind the taillights yet?
Old 02-13-2022, 05:44 PM   #3
Kaotic Lazagna
Drives: GR Corolla
If you aren't the original owner, maybe the previous one had aftermarket ones in, and quickly swapped the stock ones back and forgot to make the connections.
Old 02-13-2022, 05:50 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
in the other thread, i suggested to check the brake light switch
Valenti fourth brake light install issue spike021 Cosmetic Modification (Interior/Exterior/Lighting) 17 03-10-2022 07:26 PM
Valenti 4th Brake Light Issue Kaleb765 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-29-2021 08:07 AM
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
DIY ijdmtoy 4th brake light issue mcnvgget DIY (Do-It-Yourself) Guides 2 01-26-2020 08:03 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
