Old 02-12-2022, 09:44 AM   #1
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
older oem audio plus kit in 17+ 86 brz
Does anyone know if the older oem audio+ kits will work in the newer 86 brz with touch screen and backup cameras. Specifically curious about a 2020 86.
I contacted OEM audio+ but they are cryptic and will not give a straight answer, they're awful to deal with if you buy their kits used if anyone is wondering. Even offered to pay for consultation or anything, they just try to get you to buy a new kit.
SON1C is offline   Reply With Quote
Old 02-12-2022, 10:07 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
biggest change from previous was the harmon kardon radio in the hakone edition that bypassed the amp and didn't have an amp-turn-on output. as long as your car is using the oem amp for the doors(without the yellow-wire bypass plug connected at the amp), everything should be the same from '13-'20 in terms of wiring.
Old 02-12-2022, 10:54 AM   #3
SON1C
SON1C's Avatar
well ironically, this is a 2020 hakone.. I had no idea the HU was different. digging through this thread now..
https://www.ft86club.com/forums/showthread.php?t=139344
Old 02-12-2022, 11:44 AM   #4
soundman98
soundman98's Avatar
the threads you're looking for are going to be with @FR-S2GT86 involved. he did a ton of work with tcoat figuring out how/why the hakone radio sounded different from previous versions.
this thread in the how-to section is 1 of 2 he made about re-enabling the amp(this is the reversible plug-n-play method, the other is more non-reversible), but keeping everything else the same with the car. you're going beyond that, but if you've got a decent understanding of vehicle electrical, you should be able to figure it out from there.
https://www.ft86club.com/forums/showthread.php?t=145959
FR-S2GT86 (02-14-2022)
Old 02-13-2022, 09:54 PM   #5
reh8388
Drives: 2016 Scion FR-S Release Series 2.0
I have a 2016 with the older OEM+ system in it and recently added the head unit from the 2020 Hakone to my car. I had to add the amp turn on signal referenced in the thread linked to above by soundman98 and then everything worked fine.
reh8388 is offline   Reply With Quote
The Following User Says Thank You to reh8388 For This Useful Post:
soundman98 (02-13-2022)
Old 02-15-2022, 11:22 AM   #6
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
I don't want to be a neg but why not get a new kit?
Since its a Hakone, I would only give it the best
GPhilly is offline   Reply With Quote
Old 02-15-2022, 08:03 PM   #7
soundman98
soundman98's Avatar
because the hakone doesn't have an amp turn-on wire, i have my doubts that any struggle he's going to encounter with a used kit is going to be the same as buying a new kit.
might as well save the money and get the used kit.
WTB: Older BRZ/FR-S VeganJoy Want-To-Buy Requests 5 09-25-2021 11:21 AM
Looking for older OFT tunes (v2.076) akthegreat Software Tuning 4 05-05-2020 07:06 PM
2017 86 headunit fit in older brz? Sergeb96 BRZ First-Gen (2012+) — General Topics 3 08-02-2018 07:24 PM
Ecutek older roms Agent_D Software Tuning 32 05-02-2016 06:55 PM
Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! CamryDS Audio/Visual, Electronics, Infotainment, NAV 25 10-23-2015 09:10 AM
