Old 03-10-2020, 06:45 PM   #1
etherdude
Drives: 2020 Hakone Edition, 2015 FR-S
Issue with 2020 Head Unit - Door Speakers dead
I have a 2020 Hakone Edition that has mostly been in the garage since I purchased it in late October. I commented here when I purchased it that the new head unit is nice in that it has Android Auto. With my latest update on my Galaxy S9 to Android 10, it mostly works pretty well. However, the sound quality of the head unit SUCKS! No bass on very tepid mid range. Everything sounds tinny.
Today, I put on a fairly bass rich classical music channel on FM while the car was stopped, opened the drivers door, and listened to the door speaker. NADA, NO SOUND, NOTHING. There is a speaker in the door as I can see it when I shine a flashlight into the grill. However, for some reason, it doesn't appear to be driven by the head unit.
If you have a 2020 Toyota 86, let me know if you are experiencing the same problem. TCOAT, I think you have a Hakone edition now. Check this out.
Thanks, all.
Doug
UPDATE: March 19 - The Harmon Kardon HU was improperly installed at the port. There is an amplifier bypass plug that is supposed to be installed on one of the cables in the trunk. The amp fuse under the dash is also supposed to be removed. The installer (at the New Jersey port where these came in) apparently did the job incorrectly and just zip tied the plug to the cable but did not plug it in. Thanks to BobHarp for finding this.
etherdude is offline   Reply With Quote
Old 03-10-2020, 07:10 PM   #2
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Is it possible that for whatever reason the speakers weren't connected to the back of the unit? Might need to take the headunit to find out though.
Old 03-10-2020, 07:11 PM   #3
Thanks, all.
Doug
I don't pick it up for 15 days, 1 hour, 8 minutes and 42 seconds yet.
I did play with the sound though and it sounded slightly better than my 14. Since the subs are in the door it makes sense you have no bass if it isn't working. Probably something simple like a plug not in all the way.
I do hope by "in the garage" you mean yours not theirs!
Old 03-10-2020, 07:21 PM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
If the same head unit is used in other vehicles, it could be set up for one of them by mistake. Mine was configured for a Scion Tc when I bought the car new.
dnieves (04-04-2021), Tcoat (03-10-2020)
Old 03-10-2020, 07:23 PM   #5
Mine was as well but all the speakers works. They just sounded like crap.
Spuds (03-10-2020)
Old 03-10-2020, 07:24 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The door speakers are run off of a small amp in the trunk. ( at least on the older models. Not sure for he 2020, but its worth lifting the carpet in the trunk and looking) You may have a blown fuse. Or maybe the plug on the amp is disconnected. It could be a number of things.
I LIKE TIRES!
The Following 4 Users Say Thank You to Leonardo For This Useful Post:
ElijahF (03-11-2020), soundman98 (03-10-2020), Spuds (03-10-2020), Tcoat (03-10-2020)
Old 03-10-2020, 07:29 PM   #7
Drivers side "front"corner of trunk (just behind rear seat back)
Leonardo (03-10-2020)
Old 03-10-2020, 08:30 PM   #8
p1l0t
p1l0t's Avatar
Meh, you're under warranty still, make them fix it.
The Following 3 Users Say Thank You to p1l0t For This Useful Post:
ElijahF (03-11-2020), Irace86.2.0 (03-12-2020), The Red One (03-10-2020)
Old 03-10-2020, 08:44 PM   #9
Book appointment. Take time to take car in. Wait around for god only knows until they get to it. Get car back. Drive home.
Or
Take 5 minutes to check amp connections first. If no issue found THEN go through first option.
Old 03-10-2020, 09:22 PM   #10
p1l0t
p1l0t's Avatar
Or
Damn dealers in Canada don't have courtesy cars either?
Old 03-10-2020, 09:25 PM   #11
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
I would check the basic audio contol settings as well, may have been inadvertently touched?
Balance & Equalizer
Page 20 of the users guide.
https://www.toyota.com/t3Portal/docu...f/OM2086da.pdf
Was in my sisters Crosstrek this summer & the sound was real bad... a bit of tweeking and was much better.
Would be next step ,before you start pulling things apart...
The Red One is offline   Reply With Quote
The Following User Says Thank You to The Red One For This Useful Post:
p1l0t (03-10-2020)
Old 03-11-2020, 06:13 AM   #12
Oh they would shuttle you someplace. Still takes up your time.
p1l0t (03-11-2020)
Old 03-11-2020, 07:51 AM   #13
p1l0t
p1l0t's Avatar
Yeah but you can still answer emails and troll the web if someone else is driving.
Old 03-11-2020, 08:05 AM   #14
Doesn't mean you can't take a quick look yourself first.
I do nothing beyond checking my oil and adding windshield washer fluid to my cars these days and would still check the amp plugs before taking the car in.
Door speakers not working after new head unit install lsr78 Electronics | Audio | NAV | Infotainment 17 04-27-2021 04:23 PM
WTB: 2020 Toyota 86 OEM Radio/Head Unit burgeralert Want-To-Buy Requests 7 08-16-2020 05:49 PM
MD: BRZ Head Unit + Speakers itsfun Audio/Visual, Electronics, Infotainment, NAV 2 04-06-2013 09:03 PM
FS: Stock BRZ head unit (Sat, Nav, BT audio, etc) with amp & speakers Mach V Dan Audio/Visual, Electronics, Infotainment, NAV 20 02-18-2013 04:59 PM
New head unit/speakers Dkittrell Electronics | Audio | NAV | Infotainment 5 06-27-2012 03:01 PM
